460 cam
With any bigger cam you will need to check pushrod length, check for the right lifter preload, retainer to guide clearance, valve stem seal clearance. You can run stock rockers but I'd still check clearance in the rocker. Get the matching springs for the cam and put them in at the right installed height and check for coil bind.
Jordan Acosta
10-04-2018 05:29 PM
mpc07005
07-17-2012 09:09 PM
TonyG
02-25-2002 05:55 PM
