Molasses to remove rust ?
Old Oct 5, 2012 | 10:33 AM
HILLBILLY BOB's Avatar
HILLBILLY BOB
Question Molasses to remove rust ?
I know that this was brought up before but i forgot what you
call it.some of the guys said that they used some kind of molasses
to remove rust (i thnk that it was the guys that live on a farm)
what kind of molasses was it & where can i get it?
Old Oct 5, 2012 | 10:46 AM
Harrier's Avatar
Harrier
Here is an old thread on it:
https://www.ford-trucks.com/forums/5...t-removal.html
It says "Sulphated molasses" whatever that is.
There are youtube videos on it. This one says sulfured molasses as well.
Molasses rust removal - YouTube
"You can remove rust from metal by soaking it in a mixture of feed grade molasses and water. Ive removed rust from washers, bolts, brake rotors, auto body parts, and more. Be sure to paint or treat the surface after rinsing to avoid flash rusting.
It is important that you use a sulfured molasses, which most often can be sourced from an agricultural feed store. I typically use a 3 parts molasses to 1 part water ratio for rust removal. (Hot water works best to dissolve the molasses) Submerge your rusty parts in the solution and check back in 2-3 weeks. Severely rusty parts will require additional time. The solution can be reused, but Ive noticed that it smells like it is fermenting after 2-3 months."
There are quite a few videos of it on youtube. I have never tried it myself. I have done the Apple Cider Vinegar method.
Old Oct 5, 2012 | 11:17 AM
fastphil's Avatar
fastphil
Yes...and it does work!! I've used it before. A farm feed store should have the molasses feed.
Old Oct 5, 2012 | 11:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Somewhere I have pictures of a flathead block completely ruined by molasses. It ate out pits in every surface, to the point it could not be salvaged. No one has mentioned it apparently smells about like a sewage plant, too. There are a lot of better ways to remove rust IMO.
Old Oct 5, 2012 | 12:17 PM
FortyNiner's Avatar
FortyNiner
I've used Brer Rabbit Full Flavor molasses to remove rust from some fine thread bolts. Just covered them with the goo - didn't dilute it - and after about a week, they were actually quite clean.
Molasses naturally contains sulfur, I believe. A special process is required to produce sulfur-free versions that tend to be sold at natural food stores.
Open to corrections on this.
DW
Old Oct 5, 2012 | 01:01 PM
oldmerc's Avatar
oldmerc
oldmerc
It works but there are lots of things that work better . Ross is right it STINKS .
Old Oct 5, 2012 | 04:38 PM
tinman52's Avatar
tinman52
Welder User
I use white vinegar and water mix 2:1.....work much faster (couple days to a week) and smells much better. Works great!
Old Oct 5, 2012 | 11:37 PM
fixnair's Avatar
fixnair
I too use white vinegar and have compared side by side molasses and vinegar. The vinegar won hands down. A five gallon can of molasses cost me $20 bucks at a local animal feed store. And it was very difficult to use. A gallon of vinegar cost me only $2 bucks at Smart & final store.
I now have a five gallon pail of stinky molasses I have to get rid of. Any suggestions?
Old Oct 6, 2012 | 02:21 AM
Normalbloke's Avatar
Normalbloke
Any lime scale remover for your Bathroom works a treat. We use the Domestos black,which is a thicker gel type fluid.
Old Oct 6, 2012 | 09:58 AM
havi's Avatar
havi
I'll have the Roast Duck
I would guess to say, molasses was used back in the day as an old trick to remove rust. Nowadays, there are more efficient means of doing it. I also use the vinegar and water method.
Old Oct 7, 2012 | 06:55 AM
1952henry's Avatar
1952henry
For small parts, I simply use my bead blaster. I will vote with Havi and the rest for vinegar over molasses. I have used electrolysis quite a bit as well and love the results.
Old Oct 7, 2012 | 07:11 AM
oldmerc's Avatar
oldmerc
oldmerc
I find EvapoRust or Restore work the best for me .
pweng1
Dec 4, 2014 06:30 PM
airharley
May 21, 2008 02:52 PM
codys50ford
24
Sep 27, 2007 01:25 PM
54effie
Aug 9, 2004 07:01 AM
alanscott
Paint & Bodywork
Nov 7, 2002 09:30 PM
