On the schedule for this weekend are all new calipers, rotors and pads for the Ex. Since I am out of commission (broken ribs) my sons are coming in from college and I'm going to pull up a chair and direct while they wrench.
One thing already on my check list is to get a good measurement on my shock travel, one wheel up at the time gives me a chance to get that written down. I'm a little worried if I have enough extension or not
Since I'm going to have everything off is there anything else I should do/check while I am at it? Last weekend for awhile I will have "free offspring" labor available so want to knock out as much as possible. Thanks for any suggestions.
Check wheel bearings, ball joints, u-joints(axle shafts and drive shafts), and steering linkage. Maybe change transmission fluid and filter if it's been a while.
Have you serviced the Front and Rear diff yet? If so I would do that, Service the transmission, and Since you have new ball joints and wheel hub assemblies.
Thanks guys - all you suggested has already been one as this has been a real project truck over the last 5 months. Got 2 wheels done yesterday and starting on the other two this afternoon when I muscle help gets back.
And by the way those freaking caliper mounting bolts are a bear to break free - got some serious torque on them! Took a breaker bar and 220lbs of man stomping on the bar to release the bolts. Finally bought me a high lb torque wrench yesterday so I can get everything back on to the right torque. Still can't believe the caliper mounting bolts require 166 ft lbs.
I never torque much of anything anymore but I just get a long gas pipe and tighten untill it wont turn anymore, Most people dont agree with that but it works lol
I totally agree with that, most people are torque happy in here but even mechanics rarely torque anything. I don't torque my plugs or lug nuts and they have been just fine for 53 years.
Haha I heard the same comment last night as I was insisting he check the torque, "torqued means good and tight", finally convinced him on one thing and that was the wheel lugs. I have after market wheels on my ex and they are lug centric. With those I think it's important to make sure the torque is the same on all the lugs and they are tightened in the right pattern.
Wheels are off? Then clean and detail the inside that you can never get to while they are on the Vehicle. Every little bit counts, that little spot of mud could throw off your wheel balance or cost you less MPG's because of the additional weight...
People that wrench on vehicles all the time can look at a nut/bolt and tell how tight it needs to be. I know the torque-happy novices in here will be chiming in but whatever.
as far as the lugs tighten them down then check with a tourqe wrench. Its a game between my son and i who is the closest without over tightening. we have 4 vehicles and 2 trailers that we are constantly roating tires at this house so we get alot of practice.
while the truck is up also check behing the plastic innerfender and clean out the crud that has piled up i live in a farming area and it is amazing what get caught in the wheel wheels and under body of the excursion, expedition and f150. one night my wife brought a cat home on the top of the gas tank since then we have a cat now
I know they aren't real attractive but big mudflaps in the front that stick out 3-4 inches go a long way to keep your running board clean. I was constantly cleaning my running boards until I put mine on. I just got some generic ones and screwed directly into the inner fender panels. Drilling strategically placed holes in them first helped.
