Fuel pressure
Old Oct 4, 2012 | 06:11 PM
Rimrocksgismo's Avatar
Rimrocksgismo
Fuel pressure
Any one knows what the fuel pressure should be? I have 6 lbs when key is turned to on, and 28 at idle. I have a hot starting problem on a 96 with the 4.0 engine. I have replaced the crank sensor, temp sensor on the thermo housing, and the relay in the power distributrion box. Now testing for the fuel pump.
Any help is appreciated.
Thanks,
Tim
Old Oct 4, 2012 | 07:27 PM
aquanaut20's Avatar
aquanaut20
Key on, pump primes 32-45psi with no leak down on key off......
Old Oct 5, 2012 | 08:46 AM
Ridenred333's Avatar
Ridenred333
mine was at 38psi and periodically would drop less, once i got driving for awhile it miss and spit some. Replaced fuel pump never had a problem since. You didnt mention how old the fuel filter was. THat can cause pressure problems if clogged.
Old Oct 5, 2012 | 02:59 PM
Rimrocksgismo
Dont know history, just bought it. I plan on replacing filter and pump at same time.
Old Oct 5, 2012 | 06:18 PM
aquanaut20's Avatar
aquanaut20
Before you change the pump, check the FPR, it may be leaking.... Philip
Old Oct 6, 2012 | 08:43 AM
Rimrocksgismo
Thanks for the reply, at 160,000 miles Its probably on borrowed time as it is. I did check pressure when it was in its no start after hot symptom and the pressure did not raise over 10 while cranking.
Old Oct 6, 2012 | 08:46 AM
Rimrocksgismo
Is the FPR in the front of the fuel?
chrisjb
Mar 22, 2014 07:06 PM
MrJames159
Nov 11, 2010 08:15 PM
v8xploder
1978 - 1996 Big Bronco
Oct 12, 2009 05:46 PM
Tom Norman
Apr 14, 2005 11:21 PM
slammed96
1983 - 2012 Ranger & B-Series
Oct 7, 2003 09:26 PM
