4WD VS RWD
Old Oct 4, 2012 | 09:36 PM
jspence105's Avatar
jspence105
Originally Posted by kornfanjoe
There's a reason 4wd carries a premium in Canada eh! We need it all the time with driving to our igloos and such.
But seriously yes it's obviously in high demand in your area to have 4wd. It's better to have it and not need it than need it and not have it.
You have a few X's for sale out your way but in ontario it's like a black hole, and everything I can find is badly rusted.
Old Oct 4, 2012 | 09:58 PM
wpnaes's Avatar
wpnaes
Go west, young man...
ventura cars & trucks - all classifieds "excursion" - craigslist=
$2,900 to 29,000
Old Oct 4, 2012 | 10:42 PM
Tom's Avatar
Tom
Will you use the 4WD if you get it? I'm sure you know, but just so that there are no misunderstandings you do know that these trucks are all rear wheel driven unless switched into 4WD, right? You can't use 4WD if you will see dry pavement because the driveline will bind; this means that patches of snow on an otherwise dry road will still require RWD.
I like the advantage of a solid front axle, as it has less bushings that can wear out. I also like the fact that the camber angle is fixed as opposed to varying with the position of the front suspension like the Twin I-Beam setup is. But there is more to break on the whole, as you have a front driveline that has proven to require some service as it ages, and none of these trucks are new anymore.
So my suggestion is to buy a 4x4 unless you think you will absolutely never need it. Because you live up north I'd go for the four wheel drive unless you plan on parking for the winter.
Old Oct 4, 2012 | 10:48 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
if there is any chance of snow, get the 4x4.
it makes this much easier. i cant get out of my driveway with a 2wd.
Old Oct 5, 2012 | 05:36 AM
ufvj217's Avatar
ufvj217
Originally Posted by jspence105
I'm going to be importing, I've found nothing locally worth buying. I want to spend about 18-20K. found a couple on ebay but I'm a little worried about buying a car without looking at it first.
That money would get you a NICE low mileage diesel 4x4 down here in Florida!
Old Oct 5, 2012 | 06:01 AM
jspence105's Avatar
jspence105
You've sold me on the 4WD, thanks. Now to find one
Old Oct 5, 2012 | 05:37 PM
wpnaes's Avatar
wpnaes
Awesome second picture above Russ . Good enough to enlarge, touch up and make a poster of for your garage.
Old Oct 5, 2012 | 07:05 PM
Tom's Avatar
Tom
Looks like he has a brake fire on his passenger side rear wheel.
Old Oct 5, 2012 | 07:28 PM
jspence105's Avatar
jspence105
Naaaa that's just the snow plow pushing him down the road.
Old Oct 5, 2012 | 08:12 PM
EXv10's Avatar
EXv10
Mid mounted running board light?
Old Oct 5, 2012 | 08:35 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
55w flood lights to give me 360* light when combined with the rear flood lights. or just side slight when needed. its DARK up here in the winter.
fire? what? so lost..... ...EDIT the light looks like a fire? lol is that it.
Old Oct 5, 2012 | 08:43 PM
Tom's Avatar
Tom
See below:
Old Oct 5, 2012 | 08:48 PM
  #28
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
got ya, yup thats just a 55w halogen light
Old Oct 5, 2012 | 08:50 PM
  #29
Tom's Avatar
Tom
Wow...now THOSE are cool! Gotta link?
Old Oct 5, 2012 | 08:52 PM
  #30
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
just walmart cheapys ($20) wired to a relay(ignition hot) and switch. i plan on replacing them with some LED flood lights here soon since those have been on a year and are rusting and one has a cracked lens.
