Need help installing new belts
Old Oct 4, 2012 | 10:41 AM
Baddhabit's Avatar
Baddhabit
Hey guys I am sorry for this really simple question, but I need to replace all my belts and when looking on RockAuto.com there are a ton of options and I'm not sure what to get.
Here is the page in question - RockAuto Parts Catalog
Anyone know what specifically I should order?
Truck is an F250 7.3 Diesil w AC. I've never changed belts before, do all of the belts run off of the fan? As I notice they are listed as Fan to A/C, or Fan to Vaccum pump, Fan to P/S etc.
I thought about just ordering what I thought might cover me as they seemed pretty cheap but figured asking here first might be the better option.
Any other installation tips would be much appreciated.
Thanks,
Jake
Old Oct 4, 2012 | 12:14 PM
Phy's Avatar
Phy
How about looking at your truck & writing down what each belt goes to, then going to the catalog?
Old Oct 4, 2012 | 12:33 PM
Baddhabit's Avatar
Baddhabit
Ya I thought about doing that. I will do that when I get home. It's just I am at work right now and I was really wanting to place the order to get things moving.
Figured there was someone who had just done it that could chime in with some quick advice. They were listing a vaccum pump belt, what exactly is a vaccum pump?
Old Oct 4, 2012 | 01:21 PM
joshofalltrades's Avatar
joshofalltrades
your belts run as follows:
crankshaft-fan-alternator
alternator-vacuum pump
crankshaft-fan-power steering
crankshaft-fan-air conditioner
on models without air conditioning, the power steering has 2 belts driving it
Old Oct 4, 2012 | 01:28 PM
Baddhabit's Avatar
Baddhabit
Thank you very much.
Old Oct 4, 2012 | 02:48 PM
whiteboyslo's Avatar
whiteboyslo
Installation is pretty straight-forward. Start with the belt on the outside, then work in. For each, you'll need to loosen the accessory it drives in order to get some slack in the belt. To do this, you'll need to loosen two bolts. One will go through a slotted section on the accessory or its bracket. This is what allows the adjustment in belt tension. The other is the bolt that accessory rotates around. Kinda confusing, but stare at it for a bit and it'll make sense.
Another tip: unless they're COMPLETELY shot, throw the old belts in the truck for emergencies.
Mike
Old Oct 4, 2012 | 02:51 PM
Phy's Avatar
Phy
Diesel engines don't produce vacuum like a gas engine, because there is no throttle valve in the intake. You need vacuum for your brake booster and other things, so they have a belt-driven vacuum pump...
Old Oct 4, 2012 | 04:28 PM
81Bronk36's Avatar
81Bronk36
2 Tips:
Never buy V belts off line, there are so many variations its easier to take them in and match them up, or start in the computer then have them pull them and see if they look right. Probably be best to do it in the parking lot at advance so you can return them till you get the right one. I also keep the package they come in with the old belt in it. Of course I don't have any original accessories so that doesn't help.
Definitely keep the old belts for spares. Would be a shame to tear one in half a month later and not have an ok one lying around.
cub102
Jun 22, 2015 11:47 PM
Keithfriend
18
May 30, 2014 08:02 PM
Bluebomber94
Apr 30, 2008 12:35 PM
skrappy
Apr 8, 2006 10:47 PM
theonlybull
Oct 30, 2002 04:12 PM
