Missing and Contribution test?
Old Oct 4, 2012 | 08:49 AM
andercontracting's Avatar
andercontracting
I have a 97 f350 and it has a miss or i guess runs rough. I tested about everything I can think of besides oil pressure. When I do a Contribution test when it gets to the 4th cylinder not knowing if it is going by firing order or just in order, when it turns it off the truck runs smooth for the duration. Any ideas what to check next?
Old Oct 4, 2012 | 09:57 AM
oldbird1965's Avatar
oldbird1965
I'm not sure what you mean about it getting to the 4th cylinder? What does it do then?
Old Oct 4, 2012 | 11:02 AM
andercontracting
the test idles up the truck then I believe turns off each injector and so the truck then will shake more cause its like a dead hole. When I count and it gets to the 4th hole (dont know which hole cause I dont know if its going by firing order or just in normal order) the truck smooths out and runs perfect then when it activates it again the miss comes back, only on that one hole is when it runs smooth.
Old Oct 4, 2012 | 01:33 PM
fordpride's Avatar
fordpride
The CCT fires all 8 frist then 1-2-3-4-5-6-7-8
If it runs smooth with number 4 being shut off then you problem is with that injector or wiring to it
djmichael24951
Oct 11, 2016 03:14 PM
Fefanatic
13
Aug 19, 2016 07:48 PM
ColoradoFordBoys
Oct 5, 2014 05:12 AM
Monkeys7.3
Apr 18, 2013 02:46 PM
RustyWrangler
25
May 20, 2007 11:35 PM
