Fuel/ignition shut off switch
Old Sep 5, 2002 | 09:09 AM
mickelsons's Avatar
mickelsons
Old Sep 6, 2002 | 10:22 PM
MustangGT221's Avatar
MustangGT221
Going to college, I found that a ford truck is the 2-3rd most stolen vehicle. This has made me think about possibly installing a cut off switch, don't know which way, probably ignition? I want a switch, somewhat hidden under the dash that I can reach from the drivers seat, that will not allow you to start the engine. It'll atleast help, don't need it being stolen. I figure it's better than installing an alarm. Anyone ever do this before? I'm not sure which wires to tap into to put a switch on.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 6, 2002 | 10:54 PM
fiend's Avatar
fiend
There is a little switch behind some of the pedals that stops fuel from circulating. It's a black thing with a red tip, could always do that.
Old Sep 7, 2002 | 08:56 AM
restorit's Avatar
restorit
Do a search in the electrical forum.... lots of ideas there. Here's one thread, for starters......https://www.ford-trucks.com/dcforum/electrical/619.html. Hope this helps!
Old Sep 7, 2002 | 10:47 AM
aikigod's Avatar
aikigod
I see you're running the MSD unit, why don't you use their system to disable the ignition? I believe you run the violet wire through a switch and then to ground (if you use the white wire in your ignition setup); simply flip the switch to ground it, the engine will crank but wont start. I'm gonna try this myself when I get some free time.
Old Sep 7, 2002 | 11:41 AM
MustangGT221
Yeah, I have the 6a, i'm going to try that idea, thanks.
Old Sep 9, 2002 | 02:00 PM
gasman6674's Avatar
gasman6674
FYI
When I used to do LP gas convertions on these trucks. I would interrupt the fuel pump circuit after the inertia switch and run it to the 3-way switch we used to control the LP. That way in an crash the inertia switch shut off the LP. This is a handy place to put an anti-theft switch. No fuel no steal
Regards
Gasman
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
