What does this thing do under the hood (with video)?
Hello guys. I have been having a weird issue with my heating system in my '93 F-150. When I turn the fan mode adjustment **** on the dashboard to "off" I will get a never-ending vacuum leak sound. When I turn the **** to any of the positions (such as defrost, vent, etc) the vacuum leak sound goes away and it works fine. Turn it back to the off position, and that stupid sound comes back.
***Also: When the AC is on, the air doesn't keep coming out the same vent. It cycles on it's own between the defrost vents and the regular dash vents. Is this related? What causes that?
I took a video to show you this funny solenoid-looking thingy under the hood by the blower motor assembly, to see if anyone knew what it was for: Video of mysterious solonoid thingy - YouTube
That thing is what controls the position of the door for the heating and A/C. That line that is broken is a vacuum line. Without it that valve cannot work and your A/C will switch around from where it is blowing depending on engine load, if at all with it completely seperated. Replace or patch the vacuum line first and then take it for a drive and see the results.
That thing is the outside/inside air recirculate door vacuum motor.
No it is not the door for the heating and A/C. The heating and A/C door is cable controlled not vacuum controlled.
The outside/inside air recirculate door vacuum motor only has vacuum on it in the OFF and MAX A/C positions. That is why you only hear the vacuum leak in the OFF position but if you turned it to MAX A/C you would hear it also.
Yes you need to fix the white vacuum line to the outside/inside air recirculate door vacuum motor.
Do you remember what size that white vacuum line is? I need to do the same repair.
diesel_dan
10-09-2018 05:26 PM
yooh11
07-14-2004 09:56 AM
