Vent airflow changes when accelerating
Old Jul 6, 2004 | 11:45 PM
yooh11's Avatar
yooh11
I have a 2000 Expedition. When I have the fan or ac on blowing towards the front and then accelerate, the air stops blowing towards the front and blows in the defrost vents. If I let off the gas, it will blow towards the front again. What is this caused from?
Old Jul 7, 2004 | 10:00 AM
ckrichard's Avatar
ckrichard
My mom's Expedition has the same exact problem. It took me a long time to figgure it out, but what is causing the the door to move is vacuum, or the lack there of. The door that controls where the air goes is controled by vacuum, when you step on the gas the engine vacuum decreases and causes the door to return to the stock location, defrost vents. This is why when you let off the gas and the vacuum returns, the door moves back to the selected position. The sorce of this problem is usualy found in the vacuum resivoir, or a loose vacuum line. The best place to start is under the hood. First, start the truck, turn the the a/c on, and open the hood. Next, while standing at the rear, passenger side of the hood and facing the same way as the truck, look under the battery. You are looking for any loose or damaged vacuum lines. If you have real good hearing you will beable to hear air being sucked in. If one of the lines is lose just reconnect it and see if that fixes the problem. If it doesn't, or just makes it a little better, then the resivoir is cracked.
Chris
Old Jul 12, 2004 | 10:06 PM
lkgs's Avatar
lkgs
Having the same problem
we found a hose that had a hole in it. Does not seen to have solved the problem completely though. Where is the vacuum resivoir located?
Old Jul 13, 2004 | 11:51 PM
ckrichard's Avatar
ckrichard
The vacuum resivor is located under the battery box.
Chris
Old Jul 14, 2004 | 09:56 AM
PaulC's Avatar
PaulC
Chris has the right idea. For safety reasons, the blend door defaults to the windshield defrost position in the absence of vacuum.
scottmackay
Jun 10, 2017 10:19 AM
tk2001
2009 - 2014 F150
May 24, 2017 06:07 AM
GARY GAHAGAN
2009 - 2014 F150
Feb 3, 2017 05:54 PM
Fat Slob
18
Jul 27, 2016 06:20 PM
IIGood
Jan 21, 2016 06:12 PM
