Brake Question
Old Oct 3, 2012 | 10:05 AM
Husker fan's Avatar
Husker fan
Brake Question
I replaced my brakes and rotators a a little while ago with Akebono brakes. The replacement went fine until winter came. When I drive thru deep snow when I go to apply the brakes the peddle will go to the floor. When you let off the peddle and reapply the brakes they work fine. This does not happen any other time. The snow has to be about 6 inches or more. I have checked brake fluid levels and it is fine. Since winter is coming I am trying to get this problem figured out. I am wondering if it is just snow getting packed in behind the wheel. Any suggestions of where to start would be appreciated.
Old Oct 3, 2012 | 10:11 AM
Husker fan's Avatar
Husker fan
Forgot to mention that it is a 2005 screw FX4 with 33" tires
Old Oct 3, 2012 | 11:42 PM
mustangenthusiast34's Avatar
mustangenthusiast34
sounds like maybe air in the lines??
Old Oct 4, 2012 | 09:23 AM
tooldad's Avatar
tooldad
Just about has to be air for the peddle to go all the way to the floor, since fluid levels okay.
Old Oct 4, 2012 | 10:46 AM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
Alldatadiy.com has symptom related information that may help you with your brake issue. All at your fingertips. Good Luck!
Old Oct 4, 2012 | 04:09 PM
Husker fan's Avatar
Husker fan
Thank you everyone for the input. I will start with bleeding the brakes and see if that helps this winter. My only thought would be that if there was air in the lines then I would have brake issues all the time just not after driving thru deep snow. I will start with this and see where it takes me. Thank you
Old Oct 5, 2012 | 02:36 PM
skunkoffroad's Avatar
skunkoffroad
Sounds like an anti lock brake problem to me. Keep us posted
blue924.9
Dec 10, 2013 08:19 AM
rcosta
Oct 14, 2013 06:18 AM
trollhog
Apr 9, 2011 08:58 PM
akpilz2004
Feb 4, 2005 04:28 AM
hreed
General Automotive Discussion
16
Jan 28, 2004 10:33 PM
