Sponsored by: Kumho
Brake rotor interchangeability
Old Oct 2, 2012 | 08:46 PM
coebuilder's Avatar
coebuilder
I am building a 1951 Ford COE that I mounted on a 1986 F250 chassis. It is 2WD with a 460/C6 combination. I installed a 2000 F250 disc rear axle in the rear and have a set of Ford factory aluminum 18" wheels and tires for it. The front discs have the 8.6" wheel pattern while the rears are 170mm. Finally to my question: does anyone out there know of a way to put rotors on the frontthat will have the 170mm bolt pattern? Will a 1999 and later hub bolt up to the 1986 spindle? I know I can get a set of adapters but I would rather not if there is another alternative.
jbontke
Jul 21, 2012 08:13 AM
68murc
Mar 4, 2007 07:01 AM
Shadow05
Aug 19, 2006 02:48 PM
charliemccraney
Oct 22, 2003 04:59 PM
