Thermastats
Old Oct 1, 2012 | 08:10 PM
Mikey Oldaker's Avatar
Mikey Oldaker
Thermastats
Hey question for u guys is there a lower thermostat
Old Oct 1, 2012 | 08:14 PM
whalebus2112's Avatar
whalebus2112
You do not want the engine colder. all motors have an optimum operating temp. The 6.9 and 7.3 have an 185 degree thermostat and run around 185-200.
Why do you want it colder?
Old Oct 1, 2012 | 09:23 PM
Mikey Oldaker
Not a colder thermostat I was just online looking at a new one and it shows that there is a lower for the lower radiator hose so I was just checking because according to my temp gauge its way over what it should be
Old Oct 2, 2012 | 08:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
no. only one t-stat, and it is in the top of the engine. don't rely on the dash gauge, they are not very accurate.
Old Oct 2, 2012 | 03:27 PM
Mikey Oldaker
Kinda figured I went back and looked to make sure and they do make one for the lower but on the gauge it reads around m to a in the normal sometimes the far tip of A almost to the L so that's the only reason im concerned
Old Oct 2, 2012 | 03:33 PM
bashby's Avatar
bashby
Get an ifrared temp gun and check it, or just go ahead and get an aftermarket gauge if you are worried about it. Like TJC said, stock gauges are known to be inaccurate.
Actually, first things first, did you check your coolant level?
Old Oct 2, 2012 | 05:17 PM
whalebus2112
If you do replace your tstat ONLY USE MOTORCRAFT. The aftermarket ones do not flow as much
Old Oct 3, 2012 | 02:00 AM
Mikey Oldaker
Bash: yes i check it every day. its always a little low but only takes less than a quart to fill it back up. also good idea on the threm gun. Whale: im thinking thats what it could be is that i need a new therm again just because the first time i replaced it was in my old motor and when i did replace it it generally stayed around the R to the M and now it just goes up and yes it was an aftermarket therm so i think it may need replacing again just got to get the money to do that and my ip and glow plugs too
Macs1964F100
Nov 9, 2013 06:54 PM
shuttlevalve
May 30, 2010 02:22 PM
So-Cal Sancho
Jul 11, 2009 01:41 PM
morrigj83
Mar 20, 2004 08:41 AM
paulmal
May 4, 2002 01:14 PM
