Cutting out and now knocking
For awhile I thought it was only under acceleration, but I think it's happened under constant load or slight deceleration. I took it to have CPS changed the other day when I didn't have time to do a lot of diagonosis, but now it still has the same cutting out, and has developed an injector knock.
Codes taken by mechanic when changing CPS was a low injector pressure and a low turbo pressure. Neither one were making any warning light stay on. He did not think CPS would help based on those codes, but based on my reading here, thought it was worth a try. Obviously he was right. Any ideas?
Welcome to guzzle's In-tank Hutch Mod Web Page
The bigger issue is the cutting out - based on that Hutch mod, should I look into replacing fuel pump / dropping tank and checking things out? Fuel filter looks fairly new...I hope it's not the injector pump.
If your problem is under load, then a fuel restriction is something to look into. The in tank mods are something worth doing even if you don't have a fuel restriction (yet).
When your truck is cutting out, is it like someone turns the key off for a second? Do any dash lights flash? Does it feel like a backfire? Does it ever stall and not start back up?
Where did the new CPS come from? Change it back to the old one and see if the knocking goes away. Does the knock sound like a fuel or timing issue, or does it sound mechanical?
Good. Maybe I was thinking HPOP or something...mechanic said it was under intake and expensive due to labor. I know where the fuel pump is and have considered replacing it in the past because it is so much noisier than my '00 F250 that I used to have...wondered why so loud?
Okay, I'll consider that.
Yes, it's like a power blip, but I've never noticed anything on the dash flicker. Maybe like a backfire. Never stalls. Just happens for a split second and then keeps on truckin'. Lately, instead of just isolated blips. it has done it 3-4 times in a row (within 2-3 seconds of each other).
I think the CPS came from Advance Auto parts, it was a BTW or BRW or something like that. I kept original because I knew of the issues, so I agree that needs to go back. It made no difference in the cutting out, but the knocking seems to be new and aligns with the timing of that swap. Sounds like fuel/timing.
Pick up a CPS from Ford or International. They are about the same price as the parts stores, but have fewer problems reported with them.
After reading much on which CPS was best, I ran over to my local International dealer on got the "light gray with purple o-ring" CPS and paid $31. I compared it to the one taken out by my mechanic, who installed the light gray Advanced Auto Parts one. Basically, the Iternational one looks like the one that was in my truck originally (meaning, ever since I owned it), which I assume was put in after recall. The Advanced Auto parts looked altogether different, other than color.
Got home tonight, installed in about 15 minutes (first time for me doing this, last time was mechanic). Checked wiring condition which looked okay. Fired truck up and the erratic knock was gone. So I went for a drive on country roads and then interstate and really ran it pretty hard and no more "missing". The only difference between how I was running it before was I had my truck camper and enclosed trailer whereas tonight I just had the truck camper. However, I was trying to create extra load by driving it harder - when I had the trailer on, although extra weight, I was driving very conservatively.
I know the only way to truly test would be put the trailer back on, but it's looking pretty favorable to me. It used to not have much power without my DP Tuner and now, even with no tune, it runs smoother and seems to have more power. So I'm thinking I definitely made a change for the good.
I'll let you guys know once it really proves out or if I have more issues...
Thanks,
HRJoe
Camshaft Position Sensor 7.3 powerstroke Location and Install - YouTube
