caburetor spacers
Old Oct 1, 2012 | 04:26 PM
Ashton_1012's Avatar
Ashton_1012
caburetor spacers
hello
i have a 390 that is mildly built... i could go into detail about the aftermarket parts but im not sure if that would help much. the problem is that the linkage from the petal the throttle is rubbing against a plate on the manifold that holds the return spring. I have a 1inch spacer already, if i removed it the problem would only get worse. Adding another spacer would fix the problem, but i know it messes with stuff a bit. What do you guys think? i have a 600cfm holley and a 390 streetmaster intake.... how much would adding a spacer affect things such as mpg, hp, and torque?
Old Oct 1, 2012 | 06:37 PM
elgemcdlf's Avatar
elgemcdlf
Originally Posted by Ashton_1012
hello
Why not just bend the bracket over to the side a little bit so it clears?
Old Oct 1, 2012 | 08:35 PM
Ashton_1012
well i'd have to bend it a good inch, wasnt sure if that was a better option than adding a spacer
Old Oct 1, 2012 | 08:40 PM
Alex from GA's Avatar
Alex from GA
Usually when you increase the intake runners it increases the torque, IMO go for it. You can also get a cable throttle and junk all the messy linkage.
Old Oct 1, 2012 | 08:42 PM
Ashton_1012
i like that idea... do you know if they make cables for tranny kick downs? guy who built the truck used a copper pipe thats all bent and curved to work... looks like crap!
Old Oct 2, 2012 | 09:19 AM
19704X4F250's Avatar
19704X4F250
My '70 has a throttle pedal/cable assembly from a '79. It was a bolt in. It has a 460 with a 4 barrel. They do make aftermarket cable kick downs but you probably could get a stock kick down from a 'yard.
Lokar Performance Products: 1-877-469-7440
Old Oct 2, 2012 | 09:24 AM
19704X4F250
Trying to navigate the Lokar site was a nightmare! Here is an easier site with throttle and kick down cables......Lokar Throttle Kickdowns
Old Oct 2, 2012 | 10:49 AM
Ashton_1012
pretty dang expensive, but perhaps i will get one! thank you
Old Oct 2, 2012 | 10:59 AM
Beechkid's Avatar
Beechkid
I agree- especially with increasing the runner height....the taller the better in terms of throttle response & fuel/air atomization at lower rpms!!!!!
Old Oct 2, 2012 | 11:05 AM
Ashton_1012
I have a 1 inch ported spacer, i think i will go with another 1inch but instead an open spacer to increase the height of the intake manifold. what do you guys think? should i just go with a straight 2 inch ported? also, anyone have any idea what size threads the 390 street master intake has for the carb studs? i will need to buy taller ones to fit another inch of space.
Old Oct 2, 2012 | 11:37 AM
Ashton_1012
to late, you guys didnt answer fast enough! ordered a 1inch open alluminum spacer for 10 bucks off ebay! with two gaskets and studs, cannot beat that deal. however i have to buy taller studs, but they are cheap. Also on its way are my new plug wires, cap, and rotor hoping to see some performance upgrades after all the parts are in. Does anyone recommend getting spark plug wire heat protectors? my exhaust does get hot, but how much does the heat really harm the wires?
Old Oct 2, 2012 | 11:59 AM
Alex from GA
I believe the studs are 5/16-24.
Old Oct 2, 2012 | 12:34 PM
MIKES 68 F100's Avatar
MIKES 68 F100
those kits normally come with studs and bolts , the Fe engines really don't need plug wire heat shields , just watch how you route the wires and zip tie them away from the headers .
Old Oct 2, 2012 | 08:20 PM
Ashton_1012
well it does come with studs, but for a 1 inch spacer. i already have a 1 inch, im adding another one. Shoot well i just bought these ones: Carburetor Studs Nuts & Washers 3 5/16" Long Carb 65110 | eBay
They will work right?
Xwarrior86
Feb 26, 2019 10:32 PM
ladelld33
Aug 16, 2009 06:56 PM
WoomaHodal
Nov 12, 2006 06:44 PM
zsir
Aug 26, 2005 05:29 PM
William
Jan 10, 2003 08:02 AM
