Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
gear shift fuse
Old Sep 30, 2012 | 10:32 AM
mylittlebasketshop's Avatar
mylittlebasketshop
gear shift fuse
My gear shift fuse keeps blowing when I press on the brake of my 03 escape...
Old Sep 30, 2012 | 03:17 PM
projectSHO89's Avatar
projectSHO89
What is the fuse # (see ower's manual, if necessary)?
Old Sep 30, 2012 | 03:41 PM
mylittlebasketshop
number
#24 is the fuse number
Old Sep 30, 2012 | 03:57 PM
projectSHO89
There's a lot of stuff that runs off that fuse when the brake pedal is pressed including the brake lamps, shift lock, a whole bunch of other stuff that might be shorted to ground. While you have noticed the shift interlock issue, be advised you also have no brake lights when the fuse is blown.
There isn't any easy way to troubleshoot this without certain equipment. My wife's 07 Mariner had a similar problem last spring so that it blew the brake lamp fuse when the brake pedal was pressed. I finally found a mouse nest inside the interior panel next the right rear tail lamp. The little rat had been chewing on the wiring insulation and had caused the brake lamp wire to be shorted to the ground wire, both were stripped of insulation.
I'd suggest you do a visual examination behind the tail lights and look for any other such critter carnage throughout the truck, but other than that, you'll probably need the services of a technician who is skilled at finding short circuits.
rangergirl94
Apr 20, 2012 03:41 PM
mavfan2977
1997 - 2003 F150
17
May 25, 2008 08:14 PM
The Mad Canoeist
Nov 22, 2005 06:24 PM
bigdaddy30
Electrical Systems/Wiring
Jun 16, 2004 05:41 PM
bronco up
1978 - 1996 Big Bronco
Feb 18, 2004 06:24 PM
