Concerned About Oil
Old Sep 29, 2012 | 05:20 PM
bridge's Avatar
bridge
Sick 'n Tired
Concerned About Oil
Forgive the newb Diesel question. My rig has 3700 miles on it and the factory oil. I thought I'd give the dip-stick a look and see if there was any oil consumption thus far. The oil seems to be really dark, as in black. It also smells a little like jet fuel. I've never seen oil that black when changing the oil on my F-150, it's usually got a little brown left. Also, that dipstick isn't exactly easy to read is it?
The pics below are of a clean stick and a dipped one.
Old Sep 29, 2012 | 06:02 PM
Andrew010's Avatar
Andrew010
Welcome to owning a diesel with emissions equipment. That smell is fuel in the oil from the regen process. Diesel oil is always black btw.
Old Sep 29, 2012 | 06:26 PM
bridge's Avatar
bridge
Sick 'n Tired
Thanks Andrew. I've been a bit paranoid due to my lack of diesel knowledge and the recent posts on engine failures. I'll make myself a drink and chill.
Old Sep 29, 2012 | 06:29 PM
Andrew010's Avatar
Andrew010
As long as the fuel dilution doesn't get too bad you're fine. Have you been letting the regen process get completely done before stopping or shuting the truck off?
Old Sep 29, 2012 | 06:53 PM
bridge's Avatar
bridge
Sick 'n Tired
Not always. As is the case with others I've ready about, my truck will start a regen when I'm about a mile from home. I'm thinking of getting an Edge Insight so I can see the soot levels and know when the process is active and complete.
Old Sep 29, 2012 | 07:57 PM
FishOnOne's Avatar
FishOnOne
When my truck goes into regen I switch the LCD screen over to the instant fuel economy screen. When the instant fuel economy gauge goes back to normal I know the regen process is complete. Having watched this gauge many times I now know it takes ~ 6.5 miles for the regen process to be completed.
Because I know the number of miles to drive to complete a regen, and when the regen does occur when I'm near my destination; I look at my odometer and know I need to drive 6.5 miles to ensure my truck completes a regen before I shut the truck off.
Old Sep 29, 2012 | 08:11 PM
bridge's Avatar
bridge
Sick 'n Tired
That's clever, thanks for that. I did notice the MPGs take a dive during a regen. I've got the Torque Pro app and a BT adapater. I've been seaching for PIDs that shows all the Regen info (active, dist between, etc) but it seems they aren't readily available as of yet for the 6.7L. Looks like I'll need to start taking the long way home.
Old Sep 29, 2012 | 09:18 PM
Andrew010's Avatar
Andrew010
Or delete it and won't have to worry about regens or DEF ever again....
Old Sep 29, 2012 | 11:31 PM
remhaust's Avatar
remhaust
Yep Yep! Im sure glad i dont have to worry about that no more.
Old Sep 29, 2012 | 11:54 PM
kper05's Avatar
kper05
Yep, your fresh oil will be black shortly after changing it too once it cycles thru the engine.
Ford said 7% fuel dilution is max allowed diesel in the oil for the 6.7L and when to be concerned.
Normal driving with some towing, I end up with 2-3% dilution.
Last oil change I went out of my way as an experiment to complete active regenerations and the oil report was less than 0.5% dilution.
I guess with that dipstick it's difficult to tell how much over the max line the oil is vs the twisted metal.
Old Sep 30, 2012 | 02:45 AM
rangeron's Avatar
rangeron
May be true on newer engines with DEF, but my 2002 Duramax never had oil tht black, even when time for a oil change.
Old Sep 30, 2012 | 09:49 AM
Romeo Scorpion's Avatar
Romeo Scorpion
Your '02 Duramax would have been the exception, not the norm. Every diesel I've owned over the last 30 years turns the oil pitch-black in a couple of thousand miles. Trucks, cars, tractors, construction equipment; they all exhibited this condition.
Old Sep 30, 2012 | 10:20 AM
FishOnOne's Avatar
FishOnOne
Including my '05 6.0 psd with 6k miles on the oil it wasn't that black. Less EGR equals cleaner oil.
Old Sep 30, 2012 | 10:28 AM
remhaust's Avatar
remhaust
On every diesel ive owned,my brothers owned,my friends owned and every piece of equipment if owned and worked with as long as I have been alive has been black.And most of them had no egr systems.Yes egr and def make it worse but doesnt matter.All diesels oil should and will be black,you cant get away from it,and better yet theres nothing wrong with it other then the color,doesnt look like a gassers.
P.S.
Just because its black doesnt mean its not able to or isnt doing its job.
Old Oct 3, 2012 | 09:25 AM
CGMKCM's Avatar
CGMKCM
Take a hacksaw blade or file and cut a groove in the side of the dipstick blade. A small drill bit drilled at high and low also might work. Really makes it easy to see the oil level.
