Sponsored by: Auxito
1999 spark plugs
Old Sep 29, 2012 | 02:39 PM
Timothy Barrett's Avatar
Timothy Barrett
Question 1999 spark plugs
I have an 1999 f150 4.2l only 82,000 original miles.i have had truck since new .i just replaced the spark plugs for the first time.i used autolite plat.i also changed fuel filter the truck started to run like crap now shaking and sorta like missing.i pulled the plugs again rechecked the gp reinstalled them installed new wires still runs like crap.went out bought new motorcraft plat. plugs gapped at .054 still runs like crap..so i checked the gap on original plus that have been i the truck since new the gap on them are .074-.075. should i try and gapp the new ones to this the truck ran like a dream with the original plugs at this gap???? any ideas??
Old Sep 29, 2012 | 06:33 PM
vaper's Avatar
vaper
Did this start after the first change of plugs? If so double check the firing order.
And no don't gap the new plugs to.074 stay at 0.054
Old Sep 29, 2012 | 09:17 PM
galaxie641's Avatar
galaxie641
Pretty much either plugs wires are screwed up or you knocked something loose/forgot to plug something back in.
Old Sep 29, 2012 | 09:53 PM
Dave G.'s Avatar
Dave G.
It could still be the plugs. Autolite and Motorcraft are not the same.
Dave
Old Sep 30, 2012 | 07:09 AM
Timothy Barrett
firing order is good..yes it was the first change of plugs, and i used autolite then change to motorcraft..any possibilitiy something to do with changing fuel filter vacunm or compression..no check engine light no codes,
Old Sep 30, 2012 | 08:42 AM
dbreckman's Avatar
dbreckman
Do you still have wires or is it COP's? If it is the COP style check all of the electrical plugs and make sure they are seated firmly. You mat also have a faulty winding in one of the COP's, but it's not bad enough to set the code. There's two known ways to find this problem; the first is to have a real time reader hooked up while operating the truck, the other is to buy one new COP and use it to rotate through the order until the problem fixes (downfall to option two is if you have more than one bad).
Old Sep 30, 2012 | 08:53 AM
vaper's Avatar
vaper
Can you clarify "runs like crap"
Rough at idle,higher rpm or both?
Hard miss or random?
Did you scan the truck for pending codes?
I think something happened during the plug change focus on that.
Did you run the truck between the plug and fuel filter change?
There was a thread here a while ago on a 4.2, the op was positive the firing order was right.
After a number of posts back and forth it turned out he did indeed have the wires mixed up.
I'm not questioning your ability but check again it can happen to the best of us.
Old Sep 30, 2012 | 11:55 AM
Timothy Barrett
rough at idle very rough in gear at a red light ..shaking , higher rpm in park ..
it will get up and go while driving has good power but when u slow down and stop is when it acts up..
did scan for codes nothing...
did recheck firing order..it acted like this before i installed the wires..
plugs,fuel filter ,air filter,and oil change done the same day ,wires i did not install till the next day.
I had a mechanic friend stop by..he saying sounds and runs like a vacumn leak..
Old Sep 30, 2012 | 11:58 AM
Timothy Barrett
but we couldnt find one.. i did put in fuel injector cleaner in the gas tank and sprayed throttle body cleaner around the trottle body
Old Sep 30, 2012 | 07:38 PM
Dave G.'s Avatar
Dave G.
What does the vac actually read ? Also, with the coil packs and plug wire ignition, sometimes the metal plug clip inside the boot is too far up in the boot. Even though the boot seems to be all the way on/seated, the metal clip may not snap onto the plug. If not, arcing. The same is also possible if the boot is too far up the wire. The clip snaps on the plug, but the boot is too high, then the spark arcs to the head.
Sounds like something simple though. The engine may run a little bit rough the first couple of times though, because of all the new parts.
Dave
Old Sep 30, 2012 | 09:53 PM
galaxie641's Avatar
galaxie641
MY vote is for a vacuum hose knocked loose somewhere.
Old Oct 1, 2012 | 10:54 AM
Timothy Barrett
Thanks Dave thats what i am hoping..I am going to recheck make sure the wires are correctly connected.. Hoping its because of the new parts.being so old with low mileage..
truck actually runs good unstil u stop or in park but has plenty of get up and go.
i was also thinking vacumn i am gonna recheck all the lines.
Old Oct 1, 2012 | 05:18 PM
vaper's Avatar
vaper
Keep us posted Timothy,hope you figure this out soon
Old Oct 1, 2012 | 06:14 PM
RebColonel's Avatar
RebColonel
Have you checked the PCV valve and hose?
Old Oct 1, 2012 | 08:35 PM
Timothy Barrett
yep i did check pcv valve..i am now leaning toward IAC valve since i sprayed throttle body cleaner in it.i have been reading ford does not recommened that it could ruin the Iac valve
makes sense to me because i am experiencing idle problems and the fact it sounds like its sucking air....
anyone experience issues with the IAC valve?
