Waste gate actuator question
Old Sep 28, 2012 | 06:35 PM
sudsmcduff's Avatar
sudsmcduff
been getting the 1249 code for couple years now, have a banks big head waste gate on with banks housing and wheel. is there any better ones i can try or do i have to stay with banks cuz its a banks housing? thanks
Old Sep 29, 2012 | 09:47 AM
Pitcrw6's Avatar
Pitcrw6
What are you wanting to change? I have the same components as you but I dont have the 1249 code. If you want to change the whole thing then I would go with a 38r. I dont remember what the 1249 code is.
Old Sep 29, 2012 | 12:32 PM
sudsmcduff's Avatar
sudsmcduff
i wish but cant afford the 38r. p1249 is Wastegate Fail Steady State Test.
Old Sep 29, 2012 | 01:02 PM
Pitcrw6's Avatar
Pitcrw6
Do you have your red line disconnected?
Old Sep 29, 2012 | 01:27 PM
sudsmcduff's Avatar
sudsmcduff
i never took it off. can they come off by them selves? i will go look now
Old Sep 29, 2012 | 01:30 PM
Pitcrw6's Avatar
Pitcrw6
Yes they can come off if the rubber end is in bad condition. Check both ends. Did you try your old wastegate?
Old Sep 29, 2012 | 01:31 PM
sudsmcduff's Avatar
sudsmcduff
both of them are still all connected. i tossed the old turbo and wastegate long time ago
Old Sep 29, 2012 | 01:38 PM
Pitcrw6's Avatar
Pitcrw6
You can disconnect the red line and apply air to that end of the wastegate and see if the actuator moves. Is your rodend connected? Do you still have you old wastegate? You can try swapping them out.
Old Sep 29, 2012 | 01:41 PM
Pitcrw6's Avatar
Pitcrw6
Also did you clean your EBPS located right in front of the hpop reservoir?
Old Sep 29, 2012 | 01:45 PM
sudsmcduff's Avatar
sudsmcduff
sorry man but i have no idea what that is
Old Sep 29, 2012 | 01:46 PM
Pitcrw6's Avatar
Pitcrw6
Let me find it and send it to you.
Old Sep 29, 2012 | 01:51 PM
sudsmcduff's Avatar
sudsmcduff
thanks, i applied air and the rod moves.
Old Sep 29, 2012 | 02:00 PM
Pitcrw6's Avatar
Pitcrw6
Your EBPS is probably clogged. Try this
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Sep 29, 2012 | 02:07 PM
sudsmcduff's Avatar
sudsmcduff
thanks alot man
Old Sep 29, 2012 | 02:12 PM
Pitcrw6's Avatar
Pitcrw6
Keep us posted. Clear that code also to see if it comes back. Also how was your fuel mileage?
