View Poll Results: what do you think of this thread
it is a good thread
100.00%
it is a bad thread
0%
very good information
50.00%
poor information
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
installing a new cluster with tach
Old Mar 14, 2005 | 03:40 PM
jimbob21rc's Avatar
jimbob21rc
Lightbulb installing a new cluster with tach
<TABLE style="WIDTH: 375pt; mso-cellspacing: 1.5pt" cellPadding=0 width=500 border=0><TBODY><TR><TD style="BORDER-RIGHT: #ece9d8; PADDING-RIGHT: 0.75pt; BORDER-TOP: #ece9d8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #ece9d8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #ece9d8; BACKGROUND-COLOR: transparent">
ffice:office" /><O:p>Thought this might be of some help to some one, I am thinking of doing this also.</O:p>
This project should take less than an hour and will cost approximately $40-$100. It will allow you to retain your original odometer reading and add an OEM Tachometer.<O:p></O:p>
Purchase an instrument cluster<O:p></O:p>
It is best to get a cluster from the same year of truck as there are some minor changes across the years. (volt gauge wiring, ABS light). The clusters are not engine specific. Any cluster from a gas vehicle will work in any gas vehicle. Despite what the salvage yard tells you the tachometer wiring is already in your truck and it will plug right in. <O:p></O:p>
You may purchase a cluster from either an automatic or manual transmission truck. You can easily change it to match what you need. (later in article). A good source of used clusters is eBay or http://www.car-part.com<O:p></O:p>
Remove Old Cluster<O:p></O:p>
-Carefully pry the two silver/wood trim panels from each side of the steering column.
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype class=inlineimg id=_x0000_t75 title=\"Stick Out Tongue\" path=\"m@4@5l@4@11@9@11@9@5xe\" o:spt=\"75\" coordsize=\"21600,21600\" src="https://www.ford-trucks.com/forums/images/smilies/tongue.gif" stroked="f" alt="" filled="f" border="0" o<img></v:shapetype>referrelative="t"><v:stroke joinstyle="miter"></v:stroke><v:formulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:formulas><V:path o:connecttype="rect" gradientshapeok="t" o:extrusionok="f"></V:path><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com[img] /><o:lock v:ext=[/img]</o:lock><v:shape id=_x0000_i1025 style="WIDTH: 166.5pt; HEIGHT: 125.25pt" type="#_x0000_t75" alt=""><v:imagedata src="file:///C:/DOCUME~1/Owner/LOCALS~1/Temp/msoclip1/01/clip_image001.jpg" o:href="https://www.ford-trucks.com/articles/2003/pic1.jpg"></v:imagedata></v:shape><O:p></O:p>
-Remove the screws that are under these panels.
<v:shape id=_x0000_i1026 style="WIDTH: 187.5pt; HEIGHT: 141pt" type="#_x0000_t75" alt=""><v:imagedata src="file:///C:/DOCUME~1/Owner/LOCALS~1/Temp/msoclip1/01/clip_image002.jpg" o:href="https://www.ford-trucks.com/articles/2003/pic2.jpg"></v:imagedata></v:shape><O:p></O:p>
-Remove the headlight ****. To do this, pull the **** out, use a small screwdriver or awl to press the release tab outwards. Keep pressure on this tab while you pull the **** off.
<v:shape id=_x0000_i1027 style="WIDTH: 267.75pt; HEIGHT: 231pt" type="#_x0000_t75" alt=""><v:imagedata src="file:///C:/DOCUME~1/Owner/LOCALS~1/Temp/msoclip1/01/clip_image003.jpg" o:href="https://www.ford-trucks.com/articles/2003/pic3.jpg"></v:imagedata></v:shape><O:p></O:p>
-Pull on the dash piece and it should pop right off.<O:p></O:p>
-Pull it out far enough to gain access to the back of the Fuel tank selector switch.<O:p></O:p>
-Gently pry back the clip and pull the connector from the back of the switch.<O:p></O:p>
-The dash piece should now be free and can be set aside.<O:p></O:p>
-Remove the 4 screws that hold the entire cluster in (not the 7 screws that hold the clear face on).<O:p></O:p>
-Tip the cluster out being careful not to scratch the face.<O:p></O:p>
-Unplug the 3 connectors on the back of the cluster<O:p></O:p>
-If you have an auto transmission you will need to disconnect the indicator cable from the shifter.<O:p></O:p>
*with auto you can complete the first six steps in the next section with the cluster in the truck if you don’t want to disconnect the shift indicator from the shifter<O:p></O:p>
<O:p></O:p>
Swap in old Speedometer/Odometer<O:p></O:p>
-Remove 7 screws that hold the clear face on (torx T15 or 5.5mm socket).<O:p></O:p>
-Remove clear faceplate and set it aside carefully (scratches easily)<O:p></O:p>
-Remove 2 more screws at the bottom of the cluster<O:p></O:p>
-Pull off black trim ring<O:p></O:p>
-Remove to black screws that hold the shift indicator in (under bottom of speedo)<O:p></O:p>
-Shift indicator will pull straight out of the bottom of the cluster (blank plate for manual transmission)<O:p></O:p>
-Pull up on the 1/3<SUP>rd</SUP> of the cluster with the oil pressure and water temp gauges.<O:p></O:p>
-Repeat on the side with the voltage and fuel gauges<O:p></O:p>
-Lastly pull the speedometer out.
<v:shape id=_x0000_i1028 style="WIDTH: 225pt; HEIGHT: 165pt" type="#_x0000_t75" alt=""><v:imagedata src="file:///C:/DOCUME~1/Owner/LOCALS~1/Temp/msoclip1/01/clip_image004.jpg" o:href="https://www.ford-trucks.com/articles/2003/pic4.jpg"></v:imagedata></v:shape><O:p></O:p>
</F;INLINEIMG" />></O:p>
</FONT>
-Disassemble the new cluster in the same manner. (oil/water first, voltage/fuel second, tachometer third, speedometer last).<O:p></O:p>
-You will need to use all the parts of the new cluster except the Speedometer and shift indicator.<O:p></O:p>
-Now is a great time to inspect all the bulbs in your new backplane (white part).<O:p></O:p>
-Drop your old speedo in to the new backplane and install the gauges in reverse order.<O:p></O:p>
Reinstall cluster<O:p></O:p>
-The cluster will reinstall in reverse order<O:p></O:p>
-Make sure to plug in all 3 plugs to the cluster<O:p></O:p>
-Don’t forget the fuel tank switch, (vehicle will not start without it).<O:p></O:p>
-The results....
<v:shape id=_x0000_i1029 style="WIDTH: 375pt; HEIGHT: 162pt" type="#_x0000_t75" alt=""><v:imagedata src="file:///C:/DOCUME~1/Owner/LOCALS~1/Temp/msoclip1/01/clip_image005.jpg" o:href="https://www.ford-trucks.com/articles/2003/pic0.jpg"></v:imagedata></v:shape><O:p></O:p>
</TD></TR></TBODY></TABLE>
Old Mar 14, 2005 | 06:27 PM
crashnburn's Avatar
crashnburn
Trying to get your post count up???
Old Mar 14, 2005 | 06:36 PM
jimbob21rc's Avatar
jimbob21rc
no just thought it would be some good info for some one.
