Modular V10 (6.8l)
Y-pipe Alternative?
Old Sep 27, 2012 | 10:15 PM
truckfella's Avatar
truckfella
Y-pipe Alternative?
I was calling around some of the local exhaust shops today getting an idea on price to have a new Y-pipe welded in.
One of the shops suggested just cutting out the restrictive portion of the pipe and replacing it with a piece of full diameter pipe. And just leave the rest of the stock Y-pipe in place. Said they've done this on quite a few V10 over the years with good results.
Anyone else heard of this technique or had it done on your rig?
Old Sep 27, 2012 | 10:47 PM
dkf's Avatar
dkf
I am not seeing what you are trying to describe. The SPD y-pipe on replaces the necked down portion of the y-pipe. The y-pipe OD before and after the necked down portion is around 2 3/8". A 2.5" piece of exhaust pipe will slip over it.
Old Sep 28, 2012 | 12:18 PM
mikeismadness's Avatar
mikeismadness
Although that will help, is suggest saving up a few extra bucks and getting a y pipe and header combo.
Old Sep 28, 2012 | 12:58 PM
bakon's Avatar
bakon
Might/probably work. I wouldnt do it that way due to bends and way stock pipes meet. Think you will be looking more than half the price in labor to get it correct, then looking at cracks in the future. The stock pipe hits the side of the other where they meet. I wouldnt waste the time to do this route, knowing I would have to fix it again later.
Kind of save a buck now/ pay later.
Old Sep 28, 2012 | 01:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Well, the difference between welding in an entire y-pipe versus just replacing the necked down portions isn't going to make cracks or other issues any bigger.
If you look at the stock y-pipe, the passenger-side pipe comes into the driver's side at a 90 degree angle. If that were more of a transition (more like an actual "Y") that can only help.
The ONE thing I would consider is that is the guy going to weld in? Stainless? Because if I recall correctly, none of the V10 y-pipes available are stainless, are they?
I would go back, ask if he can put a stainless "Y" in there, instead of just replacing the necked-down pieces...
AKHunter93
15
Sep 7, 2023 12:44 PM
TheWhiteBeast
Mar 12, 2019 04:52 AM
48' fordster
Aug 6, 2009 12:11 PM
Ratkat
Aug 24, 2008 07:55 PM
BOOTROS
Exhaust Systems
Jun 13, 2005 07:40 PM
