Leaf Spring replacement with . . .
Old Sep 26, 2012 | 09:52 PM
Samsn4's Avatar
Samsn4
What can I substitute in? is it 68-73 the usual year range that has a good supply of parts that will kinda fit?
Old Sep 28, 2012 | 09:25 AM
petemcl's Avatar
petemcl
Check with Posie's Rod and Custom. They make their own springs there in Hummelstown, PA near Hershey. I bought a set of Dual Flex for the front and Super Sliders for the rear. These guys were very helpful. The picture below is after only the front springs were replaced. Dual Flex lowered the front end 2-3".
Old Sep 28, 2012 | 06:39 PM
Samsn4's Avatar
Samsn4
thanks for the contact, but for right now i"m looking to shop at the local salvage yard.
Old Sep 28, 2012 | 06:51 PM
AXracer's Avatar
AXracer
Sam, which springs are you trying to replace? With different leafs, switch to coils?
Old Sep 28, 2012 | 08:13 PM
Samsn4's Avatar
Samsn4
sorry, my head is floating from cold meds. When i pulled my rear leaf spring assembly i found a single leaf broken, so i was wondering if any earlier years would fit. like the 68-73 axles line up, would the springs also fix?
Old Sep 28, 2012 | 09:15 PM
havi's Avatar
havi
I'll have the Roast Duck
The shackles/hangers are going to determine what width springs you can use, so that leaves out a lot of the newer types, as they are wider.
acl9865
Mar 4, 2018 08:33 AM
DeathRangerofDeath
Mar 5, 2016 04:58 PM
Wallywall
Sep 10, 2010 09:34 PM
bassn1
Dec 16, 2008 10:32 PM
Fords&Farmalls
Sep 21, 2007 07:51 AM
