AOD Neutral Safety Switch
Old May 17, 2003 | 07:00 PM
medicpg's Avatar
medicpg
I just put an AOD behind my 302, I have a column from a 79 Cadilac, and I am wondering how to wire up the Neutral safety switch. Can anyone give me some quick instuctions? All of this is going into a 1954 F100.
Old May 17, 2003 | 09:41 PM
steve83's Avatar
steve83
The column has nothing to do with it.
The AOD has a position switch on the L side - get the wiring diagram for the donor vehicle and wire your start circuit so it matches. All the NSS does is break the circuit between the ignition switch and the starter relay.
Old May 17, 2003 | 10:24 PM
medicpg's Avatar
medicpg
Thanks for info. Part of the problem, As I mentioned I am modifying my 1954 F100, and one of the things I did was put in a new wiring harness.
So if I yanked the tranny from a Lincoln, get the wiring Diagram for that?
Old May 17, 2003 | 10:46 PM
steve83's Avatar
steve83
Yep.
tjdad62
17
Feb 12, 2015 01:49 PM
fatfenders56
May 15, 2012 07:23 PM
bigcountry150
Mar 11, 2011 12:51 PM
Mil1ion
Electrical Systems/Wiring
Nov 29, 2002 08:00 PM
lf_9659
May 22, 2001 10:26 PM
