FLASHER
Old Sep 26, 2012 | 01:12 PM
doodoohead's Avatar
doodoohead
FLASHER
Hi
sorry to be dopey, and ask a seemingly simple question.
2005 F350 CREW Lariat Fx4 Shortbox
Where is the Flasher or flashers located?
I am having a right rear issue with blinker/brake, but not taillamp.
Old Sep 26, 2012 | 02:03 PM
Yahiko's Avatar
Yahiko
On the 06 it's in the Auxiliary relay box 1
It looks to be center of the dash bottom
edge under/near the radio I think.
In the book is looks like the 4X4 relay
box in the engine compartment. It may only
have one thing in it if your year is the same as mine.
turn your 4ways on and listen under the
dash for the clicking.
Sean
Old Sep 26, 2012 | 02:30 PM
doodoohead's Avatar
doodoohead
Thanks
I found the flasher, will a bad flasher also make the brake lamp go out?
Old Sep 26, 2012 | 07:54 PM
Yahiko's Avatar
Yahiko
Don't think so. They should be separate circuits.
You may want to check the plug from the frame
to the bed and see how it is. Look for green fuzzy
pins in the connector. Clean it up and add some
dielectric compound to heep it dry.
Sean
NHMatt
Apr 10, 2015 07:52 PM
cuttn4fun
Mar 21, 2014 09:30 AM
doberman1
Jun 9, 2011 01:16 PM
Vollbier
24
Oct 22, 2003 10:27 PM
