some codes and questions
Old Sep 25, 2012 | 06:45 PM
maple sapper's Avatar
maple sapper
i checked my codes today and found some "soft" codes they are as follows:
p0107 which the edge evolution states as a map sensor reading out of range, low
p0478 EBPV malfunction
p0470 EBPV circuit malfunction
So looking at these, would one who knows more than me say that its all related to the EBPV. I recently started paying attention to my EBP cause I realized that my edge allows me to display 8 gauges at once. Funny thing is I am waiting for my new exhaust system (banks monster exhaust with power elbow) to arrive. From what I understand the down pipe is where this valve exists. So If I have my thoughts together properly, I will need to undo the plug for the EBPV and trick it with a resister.
as far as a map sensor, is it possible I have a intake leak?
Any commentary would be appreciated. Thanks
Old Sep 25, 2012 | 07:04 PM
BigAlsPSD's Avatar
BigAlsPSD
The EBPV is the actual valve(located in the exhaust stream, at the turbo outlet) and the actuator located in the turbo pedestal.
Yes you unplug the valve at the base, or go with a blank pedestal, and insert the resistor into the plug it will not set a code.
This is different than the EBPS reading you can view.
For the MAP, is the wiring intact? Do you have a boost fooler of some sort installed? Any bare wires for the MAP grounding?
Old Sep 25, 2012 | 08:08 PM
maple sapper
I really don't know yet. I have to dig in and see what might be happening. I just put this out there for some guidance when I do take a peek.
I also forgot to mention that my EBP average is 45. Is that normal? I'm running edge tuner on level 2 and 6637 intake mod and stock exhaust. That's all thus far.
Old Sep 25, 2012 | 08:25 PM
BigAlsPSD's Avatar
BigAlsPSD
EBP average?
EBP will vary based on boost, usually starts off around MAP, then will rise with boost.
Old Sep 25, 2012 | 08:42 PM
maple sapper
So this is where my ignorance is showing unless I have a problem and just haven't realized it yet. When my truck is idling the EBP is 40-45. When I drive it can get over 50 when I put my foot into it. I will do some more analyzing and see if I can give better info.
Old Sep 25, 2012 | 08:46 PM
BigAlsPSD's Avatar
BigAlsPSD
At idle you should be around 14psi.
You could try cleaning the Tube and Sensor before replacement
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old Sep 25, 2012 | 09:59 PM
maple sapper
I thank you for your help. I now have some things to check on this coming weekend.
Old Oct 3, 2012 | 07:45 AM
maple sapper
I tried the whole cleaning process. Does seem to me that with the amount of soot that this can be problematic for all motors. This tube dead ends and was caked. Did not change anything however. I did not replace the sensor but that's my next move.
HollywoodRCFD
Mar 1, 2014 02:16 PM
Scottwoo
Oct 1, 2010 10:13 AM
Jerrybo66
21
Aug 11, 2009 09:08 PM
amsk8er1983
Jul 30, 2009 07:12 AM
hedhntr
Sep 10, 2007 01:31 PM
