Oil viscosity damage to engine??
Old Sep 25, 2012 | 06:29 PM
Bob The Builder's Avatar
Bob The Builder
Can anyone show me proof of damage to an engine that calls for 5-20 and has 10-30 put in it?
Old Sep 25, 2012 | 07:56 PM
GwarForAll1021's Avatar
GwarForAll1021
Nope! Not at all. I seen these trucks blow with 5-20 and I seen them blow with straight 50 weight.
A lack of oil is what ruins engines. When too much gunk and built up in the oil galleys and won't allow oil to flow to needed areas will cause premature ware and failure.
In my mind ford asks for 5-20 oil for three reasons. 1. Temperature- when it's freezing cold oil will thinken and cause hard starts. Bad things. 2. Fuel efficiency- lighter oil means less less restriction in turning parts and better MPG engineers will see their grandmothers for half a MPG. 3. lighter oil flows better and even with blockages in oil pathways. Even bad oil is better than no oil.
Here's a real question for you. What makes you think 10-30 will protect better than 5-20?
Old Sep 25, 2012 | 08:29 PM
fishb8's Avatar
fishb8
Another point is the tight tolerances on these engines require a lower viscosity so that all parts are lubricated properly, a higher weight oil will not get into those smaller spacer adequately.
Old Sep 25, 2012 | 08:40 PM
02transam's Avatar
02transam
run what is recommended..............
Old Sep 26, 2012 | 05:13 PM
Bob The Builder
Trying to keep the crank away from the rod under load.
pawpaw
Oil & Lubrication
Mar 22, 2016 11:05 PM
echoy97
Escape & Escape Hybrid
Oct 6, 2004 12:31 AM
03f150man
Oil & Lubrication
Apr 14, 2003 04:17 PM
86bronco2jeff
Oil & Lubrication
Mar 25, 2003 11:32 PM
