76-79 205 tr case ?
Old Sep 25, 2012 | 04:39 PM
mr. wackodog's Avatar
mr. wackodog
76-79 205 tr case ?
good day, well would like some help if any one knows or have had the same problem . what i would like to do is switch from the small spicer u-joint to the larger 1330u-joint on frount of my rear drive shaft .i thought i had all i needed to do the job but the u-bolts i have for the bigger yoke dont fit the bigger yoke and the parts house doesnt have any that will fit . the yoke came off of a ford 205 t case 78? but it was a parts pu so not sure if it was really a 78. the yoke is not threaded so dont think it was a cv stille yoke any ideas?
Old Sep 25, 2012 | 05:13 PM
wyoming4x4's Avatar
wyoming4x4
yoke question?
the yoke you have is it a 1330 or 1350? the 1350 yoke needs a 9/16" wrench! will be installing a 1350 on my 205 tonight. upgrading all my yokes to help prevent failures. this is what i run on my other truck and been very reliable. run a 1410 series yoke on my front of transfer. my current truck I'm running a 1330 cv up front kind of a daily driver and a little abuse should hold. bronco graveyard sells all these parts is needed. If not a threaded yoke it is a u bolt style and the better of the yokes. the threaded style the caps will eventually come loose after abuse, personal experience.
Old Sep 25, 2012 | 06:50 PM
mr. wackodog
ok not sure if it is a 1330 yoke but a 5-1330x u joint fits it perfect it is not threaded but i havent found a u bolt that will fit it. the holes have a center to center of 1-1/2 inch
Old Sep 25, 2012 | 07:44 PM
mr. wackodog
thanx . went to bronco web site full of good info .
Old Sep 25, 2012 | 10:07 PM
wyoming4x4's Avatar
wyoming4x4
bronco good site.
i use bronco graveyard a lot. lots of good info to figure stuff out. If like you said it drops in and tight and no slop your good to go! any other questions drop message and see what we can do.
goodB0Y
Offroad & 4x4
Nov 7, 2017 10:13 PM
urbex
Feb 1, 2017 01:20 PM
Aesop
Jan 24, 2014 10:40 AM
jrv6a
1978 - 1996 Big Bronco
Sep 23, 2007 01:04 AM
fordnjneer
May 10, 2005 06:24 PM
