Lost power steering
Old Sep 25, 2012 | 10:52 AM
autonoz's Avatar
autonoz
Lost power steering
Sprung a leak in my high pressure hose at the fitting. Power steering worked fine. I replaced the line and now I have no power steering. I know when I pulled the line off I lost a lot of fluid, but the reservoir is still full and it does not lower like one would think if the pump is refilling. Is there a trick to bleeding this system?
Old Sep 25, 2012 | 11:15 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Jack up the truck and suspend it on jack stands so that you can freely move the wheels full left and right......
In sure that the P/S reservoir is at the full mark..... start engine and then move steering wheel full left (or right) and then opposite way...... return to center. Check and fill reservoir as required..... go thru the steering motion again and the return to center, check fluid, refilling as nesessary until it no longer requires fluid. It SHOULD then be ok.
Old Sep 25, 2012 | 09:32 PM
autonoz's Avatar
autonoz
Got it working, all is good. Thanks
Old Sep 26, 2012 | 10:14 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Thanks for stopping back and letting us all know!!! Wish everyone would do that!!!!
Reps to you.....
jimbof
2009 - 2014 F150
Jul 17, 2014 10:59 AM
ManfredVonRichtofen
27
Jan 15, 2012 10:08 PM
JIM ROLAND
15
Jul 16, 2011 05:48 PM
John Thomas II
Apr 16, 2011 12:57 PM
SSSimon
Sep 29, 2010 04:51 AM
