That time of year and my first winter with a diesel when do you guys start plugging them in? THANKS
How cold does it get where you live? The Ford brochure says these trucks have "Worry-free starting at temperatures as low as -10 degrees F without external aid". Seems like a bit of a stretch to me though...
The coldest it gets where I live is the high 20's and my trucks start up on their own unless there is a problem with the GP system.
If your batteries are good and you are running quality synthetic oil, you should not have a problem at those temps. If you do decide to plug it in, put the plug on a timer that comes on about an hour or so before you intend on using the truck.
If you are going to use your block heater, I recommend that you inspect it very carefully for any signs of damage and replace as necessary.
A few years ago our fleet manager had all the block heaters removed from all of our work trucks. We operate in California and Arizona so we can operate without those things. Our insurance premiums went down almost 20% once we verified they all were removed. Point is, they can be dangerous if used while faulty. I am sure yours is fine but it's a good idea to check it just to be sure.
A kid around the corner from me lost his truck to a faulty block heater just last winter. Total Loss. And a stinky one too.
I keep hearing people say to put your block heater on a timer to come on an hour before u want to use it. Is it harmful to the engine to just leave them plugged in all night? That's what I've always done with my gas vehicles
Your fine... The only thing it will hurt is your pocket book, due to the electrical use...
The biggest danger would come from faulty connections anywhere in the circuit. Block heaters draw around a kilowatt, and if you have a high-resistance connection anywhere in the circuit, it is going to get hot. The most likely place for that is probably going to be the plug itself, since it sits out on the front of the truck and can get corroded.
Even though I live in pretty temperate climate, I still use my block heater quite a bit. My commute is fairly short, and I like the idea of giving the truck a little head start on warming up. In the coldest months (even though it doesn't get that cold) I will set a timer to come on 3-4 hours before I start it up in the morning.
I would argue that 1 hour before you start it isn't quite long enough. I have a timer that starts the heater 2 hours before.
As for temps, I try to plug mine in below 35F, but with synthetic oil, it's so much happier about starting that I worry less about it than I did in the past.
I was thinking of installing a relay to control the block heater based on engine oil temperature. That way the truck could be left plugged in and the heater would only switch on when needed.
A thermostat that turns on in the teens and off around forty or so ought to work. Has anyone ever tried a mod like that?
my e99 will start at 12F no problem..however I had 15w40 and there was a little romp, I did not get past an idle till it warmed up...I think plugging in at that temp is better for the engine in the long run
