When to plug in? (Outside temp)
Old Sep 25, 2012 | 03:49 PM
rufushusky's Avatar
rufushusky
I have never plugged my Ford in, starts just fine for my location. Coldest I will see in SE Mass is around zero for a few hours at most on the coldest of nights. Good batteries, clean connections, a good GPR make all the difference. I am sure the T5 10w-30 I run in the winter helps too.
Old Sep 25, 2012 | 04:00 PM
SteveH-CO's Avatar
SteveH-CO
RE: temperature controlled block heater...
You can buy a 3-outlet plug tap that turns on at 34F. Most farm stores sell these for stock tank de-icers. They work well for block heaters, if you don't mind the energy use when the heater is on.
Old Sep 25, 2012 | 07:17 PM
7.3 Rocket's Avatar
7.3 Rocket
I've had my truck down to zero degrees with no block heater and it started up. Idled rough for a minute or so and it probably would've benefitted from being plugged in but anyone who tells you that you NEED to plug in at any temp above zero has something sub-par going on in their system be it glow plugs, oil, or batteries.
In the future I would probably plug my truck in if I knew it would be single digits or colder but that's about it.
Old Sep 26, 2012 | 04:07 AM
tjc transport's Avatar
tjc transport
i ain't rite
the only time i ever plugged my 88 in was when the glow plugs died.
i have never plugged my 02 in, i don't even know if it has a block heater in it.
and it gets below 0 here quite often. never any problems starting. i just let it run for a few minutes to warm up before leaving.
Old Sep 26, 2012 | 07:53 AM
ALF1999's Avatar
ALF1999
I have started mine at -15 below before without being plugged in. If everything is working correctly it isn`t a problem. Synthetic oil makes a huge difference.
Old Sep 26, 2012 | 09:28 AM
Steve8686's Avatar
Steve8686
How about if it sits for a week or two without starting in the low 20's, still Ok? maybe only need to plug in the night before using? Thanks for all the posts.
Old Sep 26, 2012 | 10:32 AM
Optimator's Avatar
Optimator
Being in southern WI, I've had to start my '01 260K without plugging her in and while letting her sit over the weekend outdoors with temperatures as low as -5°F. When starting at temperatures that cold, I let the glow plugs warm up everything and allow the GPR to switch them off after about a minute or so before I even attempt to start cranking. I've done this with batteries 3 to 4 years old. Before winter sets in, I get the batteries tested, check out the GPR for a voltage drop across the contacts, and ohm out the glow plugs, replacing parts as necessary. I used to use the stock GPR, but have switched over to the Stancor relay with no issues...that relay seems bulletproof. I only use Motocraft glow plugs. I also run with Rotella T6 5W40 and have noticed generally quicker cold starts with it. I also only purchase fuel from stations I know have high truck traffic and fill up when I'm down to half a tank. With fresh fuel, a lighter weight synthetic, and a strong functioning GP system; you shouldn't have any problems, either. If you take care of her, she'll take care of you.
Old Nov 26, 2012 | 09:51 PM
Yukon's Avatar
Yukon
As long as you let the GP's do their thing your truck will start in very cold weather. I have had mine out overnight in zero temp and may have to let the GP's go twice but she will fire. And smoke.......
Old Nov 26, 2012 | 09:53 PM
Yukon's Avatar
Yukon
I should have added, if you can get it plugged in at 10 degrees it will only help you get her started and get heat in the cab quicker. And yeah an hour is plenty of time.
Old Nov 27, 2012 | 11:55 AM
just another truck's Avatar
just another truck
I agree with these two, If I plug my truck in, it is normally either because I have a bad connection on a battery, a bad Glow plug, or my **** is feeling extreamly cold, and I dont wish to wait for a warm up.
1 hour seems to do just fine here in Michigan. temps? -10 ( worse I remember with my truck, while hunting, no plug )
Old Nov 27, 2012 | 02:35 PM
howellt39's Avatar
howellt39
Living in the Pacific NW, doesn't get too terribly cold, down in the 20's in the dead of winter usually. I'll plug it in if it's that low even though it's certainly not required. Since I've got over 240k on the clock I figure anything the makes starting a little easier on the old girl is ok by me. Plus it'll blow warm air a lot faster while I'm sitting on the seat heater!
Old Nov 27, 2012 | 05:39 PM
Ponyboychris's Avatar
Ponyboychris
My rule... If it gets below 25 degrees, I plug in for 2 hours before liftoff.
Old Jan 20, 2013 | 06:54 PM
  #28
Diesel Newb's Avatar
Diesel Newb
Trying to figure out what type of timer to get. Is a cheap one like the kind folks use to make a lamp in their house turn on at a certain time okay? Or should it be something more like this?
Old Jan 20, 2013 | 09:28 PM
  #29
KelVarnson's Avatar
KelVarnson
No, not the cheap household type, needs to be a three-prong, and at least 10 amps, but preferably more. I think the one I got was 15 amps, and I don't think it cost more than $20.
Old Jan 20, 2013 | 09:44 PM
  #30
rufushusky's Avatar
rufushusky
The block heater is 1000-1200 watts, so you need something to handle 9-11 amps.
