First time towing with 5 Star
on
Even though I have had my Mike's 5-Star ptogrammer since last December, I have not towed with it. I am towing my 31" Airstream Classic S/O at around 10,200 lbs and a 1,000 lb hitch rate. I also have a Firestone rear airbag set at 60 lbs. My '08 has a 4.10 rear and the 5 speed TS tranny. Before Mike's, I had a Diablosport Predator that I used for 80k and while I never had an issue with it(except for towing my AS I got a CEL going up lots of mtns in the west, all for "lean" settings), I WANTED a Mike's.
I am towing my AS from San Antonio, TX to Tallahassee, Fl., which is all fairly flat except for a few really tall bridges and up-downs in north Fla. Yesterday coming through New Orleans on I-10(BTW, I-10 through Louisiana on I-10 is THE worst interstate in the USA,IMHO), all of a sudden I got a CEL. Spent the night in Slidell and thought I might get lucky and it would go away, not so. Am spending the night tonight in Navar Beach and tomorrow on to Tallahassee for a few days. I will check to see what the code is some place since I forgot to load my 5-Star and left it at home. I am suspecting it is another "lean" notice since my 5-Star has been runnung on 89-Tow mode for almost 9 months and I have loved it. Mileage towing using mostly Chevron gas, is about 8.5 driving 70 where I can and 40 in Louisiana, stop and go. I will keep you posted.
Pap
Pap
When I first installed my SCT from Mike @ 5Star I was getting lean codes. I replaced all 10 coil packs. A few days later I was getting lean codes again. Mike helped me track down the problem to a cracked PCV hose. Replaced that and no problems since. The SCT brings out the performance of the V10 and any weaknesses will surface, so it is definitely a good thing.
Mine is a 2000, so the hose is outside and easy to access. I did also change the PCV just because the OEM was only about $6.
Disregarding the lean issue could be bad depending on what is causing it. In my case it was lean codes on both banks. If yours is both banks, it is likely caused by something both banks share. Apparently you have over 80,000 miles on the truck, so there is likely something that needs attention and the SCT tuner is causing the weak link to surface.
I recommend calling Mike and asking him once you find out what the codes are. He REALLY helped me a lot.
on
Funny, as soon as I unhooked my Airstream here in Tally, the CEL went off. May be a coincidence, guess I'll see when I hook back up on Saturday. The programmer on the 89-Tow really hauled the AS fine, no complaints at all. Plenty of power when I needed it, shifted great in the T-H mode.
Pap
Pap
BUMPITY bump BUMPITY bump
for 50+mi
Pap
Pap
Mike from 5 Star made me a 87 octane tow/haul program. I towed with a few weeks ago. I had my equipment trailer with my tractor loader backhoe on it. The combined weight 05 F350 and trailer was about 17k. I had no problems towing up 10%+ grades. I thought the F350 pulled as well or better than my 03 F350 7.3 PSD.
JClark86
Modular V8 (4.6L, 5.4L)
01-03-2008 08:35 PM
greenone85260
1997-2006 Expedition & Navigator
05-10-2007 07:07 PM
bgchrs2001
03-29-2006 09:03 PM
