starter issue
Old Sep 23, 2012 | 01:54 PM
dixiestripes351's Avatar
dixiestripes351
starter issue
i have a 95 f150 4.9 4x4. i have done sme research on here and found some ideas but no luck. long story short i put in a used motor because the old one was shot. i finaly got everythang back togeather and ready to start. the problem is when i turn the key all the starter dose is throw the shaft out, it dosnt spin over. the relay on the firewall sounds like its working properly. its a brand new starter and all the connection are tight nothing is corroted the battery termanels are clean and tight. i took the new starter back to the store and had it tested. it worked fine there. i did notice that the negitvie cable insulaton is soft and loose half of its length. but i wouldnt thank it would cause my issue?
Old Sep 23, 2012 | 03:48 PM
bremen242's Avatar
bremen242
It could be your ground cable. BUT, make sure you can spin the motor over by hand. You should have jammed the torque converter in the transmission, and that could cause the same problem.
If you can spin your motor over, then I would try a new cable.
Old Sep 23, 2012 | 06:20 PM
dixiestripes351
i have a manual tans and i can spin the engine over by hand. i thank im gunna try buying a new negative cable an see what happends. just kinda wired that its doin this now when it didnt do it before i swaped engines. lol
Old Sep 23, 2012 | 08:57 PM
akuhr93'f150's Avatar
akuhr93'f150
On the right track
yeah buy a new negative cable. I had a bad ground cable and it was an intermittent nightmare. It was a game of luck getting it to start, it would be fine for two weeks, then wouldn't start for two days, and then would start again. And I replaced a few other things first trying to fix the problem because my negative cable looked "fine" kinda like yours but it was shot. Replaced it last winter and it absolutely fixed it, then again I also had a new starter and fender mounted starter solenoid.
Old Sep 23, 2012 | 09:39 PM
bremen242's Avatar
bremen242
It is not weird at all. I used to be a splicer for the telco. Once that copper was exposed to salt and water, it doesn't take much to corrode those thin wires.
Once you moved the wire (disconnected your starter / etc), the wires that were exposed to water (probably the internal strands since that braided wire will hold moisture inside) broke, and now the ground wire cannot supply enough current.
Old Sep 25, 2012 | 05:58 PM
dixiestripes351
i wll try a new ground cable to see if it works if not ill try a new fender relay. its been a long rough project and i just cant seem to win. lol
Old Oct 2, 2012 | 01:15 PM
akuhr93'f150
I chased my starter problem for almost 6 months before i fixed it and it was terrible. I never knew which days it was going to start and which it wasn't, but that's what worked for me
Old Oct 4, 2012 | 07:38 PM
dixiestripes351
finally fixed the problem well not sure about fixed but all i had to do was take the negative cable off the starter an put it on one of the bolts that bolt the starter in. it worked and now after a long 6 moths of tryin to get this truck up an running, its finally running. just got a few minor issues to deal with but its all part of the game lol
Old Oct 5, 2012 | 01:34 PM
akuhr93'f150
I hope you fixed your problem for good but I have a feeling it might come back to haunt you. If it does replace your cables. Good luck!! and I have a 93 and there is no negative cable on the starter, it is grounded through the bolts that secure the starter motor.
Unless our starter motors are completley different there are two wires going to the starter, a thick one and a skinny one. The thick one is power directly to the motor and the thin one is power to the starter motor mounted solenoid. If yours is the same as mine like i think it is I have no clue how its working for you
Old Oct 5, 2012 | 06:18 PM
dixiestripes351
mine has three termanels on the motor mounted solenoid. one for the posetive from the batt, one for the negetive from the batt or what i thought it was for and another for the small signal wire
Old Oct 5, 2012 | 08:40 PM
natslo26's Avatar
natslo26
I think; what some think is the negative on the solenoid is actually the wire that completes the circuit when the solenoid is engaged causing the starter to turn the engine. :U)
Old Oct 11, 2012 | 10:34 PM
akuhr93'f150
That's new to me. I know the solenoid signal wire your talking about but my truck only has two available terminals. Guess they are different after all. Learn something new everyday
Old Oct 14, 2012 | 08:56 PM
natslo26's Avatar
natslo26
I am talking about the starter side post not the "S" wire...the solenoid is grounded to the frame, when the "S"start wire energizes the solenoid winding inside; it causes a metal plate to join the two posts making it a complete circuit causing the starter to turn...so the second post (that is sometimes confused as a ground) is just a post for the starter side wire of the circuit. :u) http://www.maliburacing.com/images/starter_solenoid.gif
tallinboy
Sep 26, 2010 09:28 AM
pauls painting
Jun 5, 2010 02:49 PM
97blueoval
Electrical Systems/Wiring
Jun 18, 2008 01:28 PM
mattmc
1997 - 2003 F150
Nov 22, 2006 11:42 PM
