Whistling
Old Sep 23, 2012 | 01:25 PM
77 2wd's Avatar
77 2wd
thanks for the advice ill try thatt!
Old Sep 23, 2012 | 01:29 PM
fmc400's Avatar
fmc400
MSEE
Make sure you do this with the engine leaned out such that it barely runs. If you don't, the jump will not be noticeable and you will not solve your problem.
Old Sep 23, 2012 | 01:43 PM
77 2wd's Avatar
77 2wd
well there is no vacuum leak around the intake manifold or carburetor, and no vacuum leaks anywhere else for that matter, any other possibilities?? i just dont understand why it would just all of a sudden start this noise. i ran it for like a week after i got it running again, and then t jsut randomly started
Old Sep 23, 2012 | 05:18 PM
jacks61ford's Avatar
jacks61ford
take the belts off one at a time maybe it's a pulley somewhere
Old Sep 23, 2012 | 10:08 PM
77 2wd's Avatar
77 2wd
well i went digging deep into the threads and found that smoken choken had the same issue, well long story short i replaced the base gasket under my carb, and wala the whistling stopped!!
75N
Mar 17, 2015 11:42 PM
meanv10
Apr 23, 2009 08:34 AM
stevorino
Aug 12, 2006 10:24 AM
southsidej
May 30, 2005 06:22 PM
gt5-33
May 28, 2005 09:02 PM
