Truck won't start
Old Sep 21, 2012 | 04:21 PM
Matthew Tate's Avatar
Matthew Tate
Cool Truck won't start
Hey guys name is Matthew Tate
I just bought a 96 f-250 7.3 diesel from a good friend of mine because he didn't have the money to swap out the clutch it needed. So i buy the truck change the clutch, give all new filters, and oil change. Now i drive for bout a day to see if anything else is wrong with it.
On the second day im driving down the road and it just shuts off, i had to tow it back to the house. It cranks and cranks but it wont' start, i checkd all the fuses, changed the injector sensor next to the valve cover cause it had oil leaking into the plug and still nothing. Any help would very appreciated, driving me nuts.
Old Sep 21, 2012 | 04:48 PM
Hussler's Avatar
Hussler
Does the WTS (wait to start) light come on momentarily when turning the key to run?
Old Sep 21, 2012 | 05:08 PM
96ford250's Avatar
96ford250
What's been done to the truck any mods or "upgrades"
Old Sep 21, 2012 | 06:01 PM
427 fordman's Avatar
427 fordman
If the answer to to what Jim asked is no, unplug the fuel bowl heater and replace fuse 22 under the hood.
If the answer is yes, but the tach doesn't move while cranking, replace the cps with a ford or IH part.
If neither one of these are your problem, we will move on.
Old Sep 21, 2012 | 06:14 PM
Matthew Tate
yeah the wts light comes on, no mods, and i replaced the crank sensor to. Also was just outside messing with it and the ipr wires are fried, the sensor on the High pressure oil pump. was wondering if you could jump those and would run.
just checkd to make sure i was getting power back to the fuel tanks and i am
Old Sep 21, 2012 | 06:21 PM
427 fordman
No, you can't jump those. You can use an injector harness end if you have one, they are the same, or so I read. I just replaed my ipr and wiring pigtail, my wiring was a mess also and probably about to leave me just like what happened to you.
Old Sep 21, 2012 | 06:27 PM
Matthew Tate
Smile
are u supose to hear the fuel pump run when u turn the key and where do u check the fuel pressure at ?
Old Sep 21, 2012 | 06:36 PM
427 fordman
No, you won't hear the pump run. It's not electric until the super duty model, its mechanical in the obs. You can check pressure at the regulator on the side of the fuel bowl. There is a schrader valve there, put a cheapo tire gauge on it if you don't have a fuel pressure gauge. Have someone crank it and see what you have.
Do you have any smoke out the tailpipe while cranking? Those fried ipr wires are probably all your problem.
Old Sep 21, 2012 | 06:41 PM
Matthew Tate
yeah it pours white smoke on the first crank and you have to give it a tiny shot of either but after that its fine
Old Sep 21, 2012 | 06:47 PM
427 fordman
You really want to avoid ether with these trucks, unless you disable the glow plugs, in case you don't know that.
Old Sep 21, 2012 | 06:49 PM
Matthew Tate
yeah i know either is not a good thing, problem is id say its already hookd cause the old man i got it off of was already using either. the plugs won't fire it by itself without a lot of cranking and they are all new i replaced them. I haven't tried the block heater though
Old Sep 21, 2012 | 06:51 PM
427 fordman
Is the gpr in working condition? You really want to fix that, ether has destroyed more than one powerstroke, literally.
Old Sep 21, 2012 | 06:54 PM
Matthew Tate
what is the gpr?
Old Sep 21, 2012 | 07:03 PM
427 fordman
That is the solenoid on the top of the motor right/middle area. It activates the glow plugs. I think one post is hot all the time, and the other should be hot when the key is on. I'm no electrical expert by any means, but i'm pretty sure that is right. Jumping the two big posts on it will activate the glow plugs if it isn't working. You can hold a jumper on it for 30 seconds, then if it fires you know its bad.
Old Sep 21, 2012 | 07:05 PM
Matthew Tate
ah okay i got you. i haven't checked it per say but i can hear it click when i turn the key on
