best gears with a straight 6?
ive heard changing gears can help get more power to the wheels and improve mileage. What gear ratio does better on the 4.9?
My dad swapped his gears on his 97 with im not sure what but its a 4.6 and you could feel a difference.
any feedback is appreciated, thanks.
At the risk of being mean, your question is kinda dumb. "Best" gearing means so many different things depending on what you want from the truck. You mention fuel mileage, but then you mention getting more power to the wheels. The two are somewhat conflicting goals as one objective wants to see you turning the fewest RPM's while the other wants high RPM's.
The 300 makes power at low RPM and doesn't rev very high so a 3.55 on a stock truck is a good ratio to allow the engine to cruise at highway speed but not kill the low-end grunt they're famous for. However what trans you have is important. My dad has an '87 bronco with a 300 mated to the old t19 4-speed which has a granny first gear and no OD so it has 3.08:1 gears which is a good match, I might even say he could go taller to get lower highway RPM since the granny low could overcome the tall gears if need be, being a bone-stock bronco.
Trans, intended use, and tire size are important things to consider when selecting gears.
on
Yeah it's anybodys guess what Ford was thinking, a truck with that configuration had a 0 lbs tow rating, no that's not a misprint the truck is not rated to tow anything.. ZERO. What was the point?
