Fx4 EB - need advice or input
Old Sep 20, 2012 | 06:17 PM
TOOLOUD1's Avatar
TOOLOUD1
Hey I have a 11' fx4 EB screw and I am wanting to get a utility trailer like a 22' bumper pull or a 24' GN. Does anybody have any real world experience pulling a GN with a screw short bed ? I will be pulling a 40hp kubota tractor with my 7'disk and 6'bush hog a few times a year and a few atv's several times a year. What would y'all recommend ? Bumper pull or GN ?
Old Sep 20, 2012 | 06:48 PM
blueovelboy's Avatar
blueovelboy
my cousin has a goose neck he pulls with his 06 crew cab 5.5 box. its just like any other truck out there but you cant make as tight of turns it it so he sates. i like bumper pull trailers but GN are way easer to get around in tight spots!
Old Sep 20, 2012 | 06:59 PM
TOOLOUD1's Avatar
TOOLOUD1
Yeah I have always pulled big trailers with my previous trucks. I am basically trying to get some input on which might pull the best. I also want the weight to be distributed the best.
Old Sep 20, 2012 | 07:09 PM
TOOLOUD1's Avatar
TOOLOUD1
Blue- what kind of weight does you're cousin pull on the GN
Old Sep 21, 2012 | 07:20 AM
96sherm's Avatar
96sherm
G/N will distribute the weight best as the hitch is usually centered over your axle rather than the most rearward point of your truck. I've seen some "high rise" G/N trailers that would appear to give a short box very near the articulation of a longer box... If you go G/N make sure and spend the extra money to get a "turnover ball" style of hitch so you can have the bed flat and usable when you're not towing.
Old Sep 23, 2012 | 11:47 AM
shortride's Avatar
shortride
I don't think I would mount a GN on a F150 mainly because I believe it would hurt the resale value. Not many people pull anything with an F150 with a goose-neck. Other than that a GN will improve the turning radius noticeably and distribute weight better and if you don't mind something a lot closer to the rear window.
Old Sep 23, 2012 | 11:56 AM
TOOLOUD1's Avatar
TOOLOUD1
Thanks , i plan on keeping it until she cost me (maintaince )more to drive it than I would be paying on a note. I am leaning towards a GN mainly cause the weight will be over the rear axle vs hanging off the tail end , my truck only weighs 5800# with me in it.
Old Sep 23, 2012 | 03:18 PM
NASSTY's Avatar
NASSTY
It sounds like you need a GN and a set of airbags.
Old Sep 23, 2012 | 03:28 PM
TOOLOUD1's Avatar
TOOLOUD1
Got bags now just gotta decide which route I wanna go. I borrowed a 22' car hauler to haul my tractor/disk/bush hog/ box blade this weekend. I will see how it pulls on this road trip , but I don't have room for my 800 ranger - main reason I want a GN ( so I can load the ranger sideways ontop of the rails )
Old Sep 23, 2012 | 05:12 PM
capn kirk's Avatar
capn kirk
subscribing, I have a buddy thinking about the same basic thing but the trailer would be used for motorcycles
Old Sep 23, 2012 | 05:23 PM
blueovelboy
sorry it been awhile but we put about 10 to 12 pigs in there and take them to fairs across the valley. every now and then he takes a cow to the slater house. so to give you a total lbs i have no clue but i know the pigs weigh in about 150 lbs to 350 lbs, and the last cow was 643 lbs butchered out
Old Sep 23, 2012 | 05:55 PM
TOOLOUD1's Avatar
TOOLOUD1
Gotcha blueoval
Old Sep 30, 2012 | 07:25 PM
TOOLOUD1's Avatar
TOOLOUD1
Well a quick update : I borrowed A 22' x 102" car hauler this weekend to haul my 7' disk ( w/ huge chunk on concrete ) 6' bush hog and 6' box blade and a 40 HP John Deere tractor and IT PULLED great ! I set my cruise at 75 and zero sway ! Btw I also had 1000lbs of corn and feed in the bed. So I guess I will begin the search for a 22-24' bumper pull trailer. I know a GN would pull better but the added cost I just can't justify to pull 2-3 times a year.
Old Oct 1, 2012 | 08:56 AM
johnday's Avatar
johnday
You may want to consider a "properly" set up load equalizing hitch, with the torsion bars and maybe a sway bar setup. With this you can set it up so truck rides close to level so you aren't blinding on coming traffic with your lowbeams, let alone not getting the light in the front end syndrome. I'm on the road everyday in a 42 wheeler, and cringe everytime I see a pickup looking like it is being launched into space. It's not just 1/2 ton pickups either.
On my 150, I just had airbags installed. I hooked my 7ton flatbed, empty, amd the tail sagged with just the tongue weight from the trailer. To be honest, even my Super Dude with overload springs squated just a bit as well. I manage to move the load around on the deck a bit to help some of the sag, but you still want 10% or more of total trailer weight on that hitch, or you run into sway problems.
Goosenecks are nice, but I have a cap that stays on the truck forever, so in my case, a bumper pull is the only way to go.
Old Oct 1, 2012 | 09:13 AM
TOOLOUD1's Avatar
TOOLOUD1
With the above load this weekend my truck sat level as I had the majority of the weight on the axles of the trailer.
