Lightning headers on a 302
Old 09-22-2012, 05:47 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Found a set of Stock lightning headers for cheap, Would they work on my 96 302?
Old 09-22-2012, 06:59 PM
cjben's Avatar
cjben
cjben is offline
not familiar with those headers. Are they long tubes or shorties? Either way,they will bolt up to the heads,but the rest of the exhaust will need to be modified because the 351 is taller then the 302 so the exit points will be different. you may also have to add a bung for the O2 sensor.
Old 09-22-2012, 08:07 PM
Diesel_Brad
Shorty headers that go to a Y pipe. I was told I would need a 351 Y pipe to work with the headers
Old 09-22-2012, 08:24 PM
cjben's Avatar
cjben
cjben is offline
yes,that is true,or the one for the 302 could be modified to work. The 5.8 is taller/wider then the 5.0 so the exhaust would need adjustments to make it work.
Old 09-22-2012, 08:30 PM
danr1's Avatar
danr1
danr1 is offline
See now I would think you'd need a y pipe for a 302 rather then the 351 even thought the headers are for a 351.
Looked up couple sets of headers, as suspected the part numbers are different 302 / 351.
Suspect your looking for someone that's already done it/tried it, get a solid answer either way!
Old 09-22-2012, 08:44 PM
Diesel_Brad
YES, that is what I was hoping for
Old 09-23-2012, 12:17 PM
wicat3's Avatar
wicat3
wicat3 is offline
I put mustang headers on my 302 and a magnaflow y pipe and because of how the headers dumpped I had to modify my y pipe. I would just roughly eye them and see how they look to be around your y pipe and go from there
Old 09-23-2012, 10:48 PM
86F150302's Avatar
86F150302
86F150302 is offline
I cant remember his name. ( I havent been getting on much) but he has a Lightning and a 302 F150 and he used the lightning shortys but Im not sure about what the rest of his setup was.
Ill try and find him.
EDIT: Highvoltj
https://www.ford-trucks.com/forums/1...-thread-2.html
Old 09-24-2012, 06:25 AM
Diesel_Brad
EDIT: Highvoltj
OK thanks, He used a Lightning Bassani Y-pipe
2005f-150
05-17-2012 12:04 PM
darthice
04-28-2010 10:13 AM
DictatorDanny
Exhaust Systems
07-02-2006 06:08 PM
jwtaylor
31
10-25-2003 12:25 PM
Quick Reply: Lightning headers on a 302
