I am looking at an 06 XLS Escape with the 2.3L and manual transmission, FWD. I intend to tow it behind a motorhome. Does anyone know what you do to flat tow? I assume put it in neutral with the ignition on? Does this model have a timing chain or belt? Is there anything to look out for with the engine and transmission or other significant issues with this model? Thanks.
Reason: add description
The engine is a Duratec it has a timing chain.They are really good engines.Don't know about towing.The Escape problems are few mostly wheel bearings going out My first one went at 140,000.Other then that sway bar end links
Check with the laws of the states you are traveling, a lot these days are requiring some kind of brake actuation system and wiring interconnect along with a steering travel lock.
Right from the owner's manual:
RECREATIONAL TOWING
An example of “recreational towing” is towing your vehicle behind a
motorhome.
If your vehicle is automatic transaxle equipped, with a 4x2 (front-wheel
drive only) configured powertrain, “recreational towing” is permitted by
trailering the vehicle with its front wheels on a dolly. This protects the
transmission’s internal mechanical components from potential lack of
lubrication damage.
If your vehicle is automatic transaxle equipped and 4WD (all-wheel
drive), “recreational towing” is permitted only if the vehicle is trailered
with all four (4) wheels off the ground. Otherwise, no “recreational
towing” is permitted.
If your vehicle is manual transaxle equipped and 2WD or 4WD, shifting
the transaxle into neutral permits “flat-towing” (all wheels on the
ground) for pulling behind a motorhome. Your vehicle, with well
designed towing equipment, may be towed up to a speed of 113 km/h
(70 mph) but you should always obey local speed limits.
