Torque Spec's
09-20-2012, 01:25 PM
on
Torque Spec's
Changing trans fluid & filter, Tranfers case fluid, front & rear difffentials fluids. Need to know bolt torque spec's. Can anyone help me?
2002 Excursion V-10
09-20-2012, 02:29 PM
Quote:
Originally Posted by
2002 Excursion
2002 Excursion V-10
Who needs 'em.......not me. That stuff doesn't need to be tight, take it easy.
09-20-2012, 03:27 PM
rear axle oil filler plug - 15-30 lb-ft
front axle oil filler plug - 20 lb-ft
Trans pan bolts - 11 lb-ft (4R100 trans)
Source - Ford 2005 Truck Specifications Book
09-20-2012, 03:38 PM
on
Thanks Bion (AKA:Zombie Crusher)
I'm taking both differential covers off to do a thorough cleaning. You wouldn't have the bolts torque spec's for front & back would you?
Thanks a heap!!!
2002 Excursion
09-20-2012, 04:34 PM
2002 Excursion
Thanks a heap!!!
2002 Excursion
Just go easy, it's not a problem.
09-20-2012, 04:44 PM
on
Thanks Brent. I'll keep that in mind.
09-20-2012, 05:38 PM
EXv10
If that were the case they wouldn't bother with torque specs. But they do:
Rear diff cover: 28-38 ft-lbs
Front diff cover: 35 ft-lbs
09-20-2012, 05:41 PM
Crazy001
99% of the mechanics would never torque those........guaranteed.
You can find specs for almost anything.
09-20-2012, 05:42 PM
EXv10
Completely believe it. Which is why I do my own work!
09-20-2012, 07:51 PM
Crazy001
I bet you torque your catchup bottle
09-20-2012, 07:54 PM
EXv10
I find no torque value for a catchup bottle. I do see one for a ketchup bottle though. I wonder if this is one of those torque to yield thingies....
09-20-2012, 09:12 PM
Crazy001
You found a torque value for a ketchup bottle? Do tell, I need it.
09-20-2012, 09:30 PM
09-20-2012, 10:54 PM
Crazy001
I wonder if it's the same value as for a catsup bottle cap.
Hmmmmmmm...
Stewart
09-20-2012, 11:33 PM
Stewart_H
Hmmmmmmm...
Stewart
Actually my Heinz bottle says ketchup but I thought it was catsup but ended up with a compromise of catchup.
