Stage 2's
Old Sep 21, 2012 | 09:19 PM
oldbird1965's Avatar
oldbird1965
Thanks Travis for the input. This sorta go along with what Mike said. He said if I'm not racing it or pulling sleds that I would be fine without the head studs or value springs. Maybe I'll just do them anyway this winter. Hope your project is going good!
Old Sep 24, 2012 | 12:58 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Originally Posted by fordpride
Travis when you say stageII's do you mean 160/80 or 180/80 ?
160/80's is what I usually mean when I say stage 2's.
Glenn, IMO if you get it together and it starts getting up around 35+psi, I would start looking into doing studs and springs. Don't take that as saying that much boost will blow the head gaskets though. Cylinder pressure is what lifts the heads. Boost, backpressure, as well as RPMs can float the valves though. If I was in there doing springs, I'd go ahead and do studs at the same time.
Old Sep 24, 2012 | 11:15 PM
oldbird1965
Thanks Travis, something to think about. With what I got right now about the worst it gets is I'm in second gear, 40mph, about 14 to 15psi of boost, 1250 EGT and around 3K in rpm's. I've held that for four, five miles with the motor staying relatively cool, amazing cooling systems on these trucks.
microdevil45
32
May 31, 2015 01:57 AM
PlimptonJr
33
May 8, 2013 08:08 AM
idt-572
17
Dec 12, 2012 09:35 PM
Franko72
17
Oct 27, 2012 05:54 PM
DUALLYNOTED
Computer Chips & Tuners
Oct 13, 2006 09:14 PM
