76 highboy wiring
Old Sep 19, 2012 | 02:54 PM
GillisB93's Avatar
GillisB93
76 highboy wiring
My question is does the way the alternator is wired up have anything to do with the truck not getting spark. old motor that i pulled out ran put mine in and no spark. ground from the frame to the motor and motor to the cab.im not to sure on how to wire up the alternator anyone have a diagram or something.
Old Sep 19, 2012 | 04:14 PM
fmc400's Avatar
fmc400
MSEE
No.
Does your truck (not the donor vehicle) have an ALT light, or an ammeter in the dash?
Old Sep 22, 2012 | 08:08 AM
GillisB93's Avatar
GillisB93
i have a alt gauge and it does not read anything. also i got the truck to start but the alt still is not working. need help with the wires
Old Sep 22, 2012 | 04:10 PM
fmc400's Avatar
fmc400
MSEE
If you have an ammeter instead of an ALT light, then you'll have a GREEN with RED stripe wire coming from the cab which goes to the 'S' terminal of the voltage regulator. The 'I' terminal of the voltage regulator is unused. The 'F' terminal of the voltage regulator goes directly to the FLD terminal of the alternator. The output stud of the alternator (usually marked A or B+) goes to the battery side of the starter solenoid through a fusible link, which also branches off to the 'A' terminal of the voltage regulator. Some wiring harnesses also connect a ground (GND) stud of the alternator to one of the regulator mounting bolts.
What have you done to verify that the alternator is not working? What are you considering "not working?" How have you narrowed it down to the alternator? The ammeter in the dash is never going to move, even if the alternator is working.
fmc400's Avatar
fmc400
MSEE
Double post.
Codeseven
Electrical Systems/Wiring
May 8, 2016 01:30 PM
86ford302help
Oct 11, 2013 05:11 AM
ktz78
Dec 20, 2010 11:10 PM
johncardi
Jul 5, 2009 11:11 PM
rfgree
Mar 2, 2003 12:56 AM
