A/C defaulting to defrost while climbing grades
Old Sep 18, 2012 | 04:28 PM
totandk's Avatar
totandk
New member here, searching the site for a similar problem with a f350 hd van when climbing a minor grade the a/c defaults to the defrost -still cold air, where do I find the vacumm canister to check the lines for leaks or faults. I have checked in engine compartment and lines are good. Could there be a problem in the rear air???
Old Sep 19, 2012 | 12:15 AM
powerstroke72's Avatar
powerstroke72
Welcome to FTE totandk.
Since you have a van instead of a Super Duty truck, I've moved your post out of the thread in the Super Duty forum and into its own thread in the 1968 - Present Full Size Van forum.
Old Sep 19, 2012 | 09:38 AM
subford's Avatar
subford
With a 2013 van I think you take it back to the dealer you bought it from.
Your profile say 2013 anyway.
Old Sep 19, 2012 | 09:47 AM
95e150CW's Avatar
95e150CW
What year? What engine?
Many people go after the canister via cutting a hole in the wheel well. If not, you have to remove the dashboard.
The check valve sometimes fails. Sometimes just adding a cheap check valve between the engine and the AC system (which is quite easy to do) can resolve the problem.
Wamba
Oct 12, 2023 10:46 PM
tuquoiseturtle
Jul 15, 2016 06:15 PM
ogarcia434
Mar 9, 2016 06:08 AM
tx2sturgis
Sep 16, 2015 08:06 AM
ClatonK
Sep 7, 2004 10:52 AM
