How painful is it to change the inner seals on a Dana 50? Did some searching and couldn't find the step-by-step that are always out there for the tough jobs on this truck. After 138k miles, she's never made a mess on the driveway...until yesterday. I had the hubs locked in after needing them on a slippery boat ramp on Sunday. Ran for about 40 miles with the hubs on, then 200 with them unlocked and seems I shooke loose the seals. Pretty sure that's what it is...thick clean oil, smells like gear oil.
Picture taken of RF, at bumper, looking towards rear.
I had this same problem and the hub being unlocked was actually still stuck locked which causes the axle to vibrate and fluid to leak check this out first.
Oh that's interesting... Wouldn't surprise me given the reputation the hubs on these trucks have. So how could you check this? Would the front drive-shaft still spin if you have a hub that is stuck locked?
You need to pull the axles and carrier to change the inner seals. There are special tools for removing and installing the seals that make the job easier. It is best to use OEM parts as this is a job you do not want to do twice.
Gotta pull the wheels, axles, carrier, carrier bearings, Then you can get to the seals.
And while you are at it, you probably will want to change the ball joints since you will have done 90% of the work involved anyway.
You DO NOT have to remove the axle housing from the truck.
If you do it right, you only need one specialty tool. The tool to press in the seals.
Lots of folks do not use the tool, but there is always a risk of not getting them in straight without it. About $100 to 150 if you buy it, and about $20 if you make one.
If you decide to do it yourself, I recommend that you get the book, Differentials, From Randy's Ring and Pinion.
Remember to keep everything clean and free of dirt on the work table and clean everything before it goes back in.
If you have just one hub that is locked, the wheel will spin the axle shaft and it could spin the driveshaft.
The driveshaft won't spin because the spider gears can't overcome the friction and weight of the reverse 4 to 1 +- gearing (ring pushing pinion) and one axle will spin with the locked hub and the other one will be spinning backwards even though the unlocked hub is spinning forward.
I don't think that's possible; not trying to argue.
P
You can't shake loose those seals. I think you got water in the carrier area because that seal designed to keep oil in, not to keep things out. The extra volume in the carrier could then force it's contents back out. I would drain and refill the carrier and stay out of the lake water.
I think I just saved you a ton of work, you can send the check to me at Mt Shasta Ca.
If he put his front axle underwater enough to get water in it on a boat ramp, the tailgateof the truck would be seriously in the water. Besides, it would blow out of the axle vent first, not the seals.
Also, the other axle cannot spin backwards. It is on the ground! The force will go into turning the driveshaft.
Yes I am correct here and have already explained why (just the wheel is on the ground). I will have to admit a mistake here; I was thinking the front was in the water (you can tell I never had a boat), but if water did get in there it will stay in there and only air would come out the vent. If the vent is clogged excess pressure caused by driving while both hubs are locked can force oil out the seals.
LOL...I can definitely say neither axle has been in the water. No, at low tide we get a lot of algae on a steep ramp. You're just not getting 5k lbs of boat up that ramp without 4x4.
Well, I guess the big question now is, when to get this fixed. I need the truck badly over the next 2 weeks, but with oil leaking out, don't want to hose the front axle.
Check your air vent, if it is plugged it can push oil out the seal. Those seals are up next to the gears and don't normally spill that much oil in just one shot. Check your oil level also. The oil level is below the bottom of the seal when static so even with a bad seal you could take it on vacation and use 4wd if necessary with no problem.
Housedad; If you jack up the back of the truck, put it in neutral, and spin one wheel the other one will spin backwards. Let's say you cut the axle on the other side near the wheel and put it all back together, what would happen now?............get it?
It has nothing to do with the wheel being on the ground.
Never thought of the vent...but that makes sense. I'll see if I can disconnect both ends and blow it out. Was ironic this happened right after I had the hubs locked in for about 40 miles...after a period of time I couldn't remember the last time I used them. Probably over a year ago... Florida...unless someone is in the ditch, 4x4 doesn't get much exercise!
