Quick A/C question.
Old Sep 18, 2012 | 01:55 PM
Reidicus's Avatar
Reidicus
Quick A/C question.
My A/C wont enguage on its own. I have to manually tap the front of the pulley plate for it to lock in. I removed the wiring harness and checked for any shafing and burnt contacts. All is good. I put it back on and it worked! Tried it this morning and its back to the way it was. I heard that the gap between the pulley and plate need to be a certian distance. Or is it not working properly because it may need a recharge? No oil or residue around the A/C. Looks bran new to me.
Old Sep 18, 2012 | 02:27 PM
lhud's Avatar
lhud
If for some reason the system is seeing either a high or low pressure the switches will not allow the compressor to engage. However, If you can tap on the pulley and cause it to engage then it sounds like the air gap on the clutch plate is too much. Do a search for the air gap and there are written procedures to fix that. I did mine a while back and has certainly improved its operation.
Old Sep 18, 2012 | 03:05 PM
Reidicus's Avatar
Reidicus
I have found this SpringerPop's Compressor Clutch Air Gap
Only problem is that I dont have enough clerance to get the socket and wrench to reach the nut. Keep hitting the overfill bottle. Need a shorter socket.
Old Sep 18, 2012 | 06:14 PM
carltonwebb's Avatar
carltonwebb
You could take the bottle off. Not but a couple small screws that hold it in.
annaleigh
Jun 25, 2016 04:11 PM
rzrbaxfan
Sep 15, 2011 02:04 PM
Dan's_Explorer
May 12, 2011 08:18 AM
jrpoland
Aug 28, 2007 02:57 AM
brian12357
Jul 4, 2006 08:10 PM
