Whats Going On Here??
Old Sep 18, 2012 | 10:41 AM
h2guy's Avatar
h2guy
Rolled up to a stoplight, engine went to idle, and then cutoff. Immediately restarted normally. Thought "Oh no, cps is going out".
Bout three hrs later, after being parked during this time, turned ignition on, and everything on instrument panel is very very dim. Barely can see ABS light, no WTS at all.
Turned on overhead cabin light and its very dim. Wiggled key & steering wheel, tried again, same condition. Raised hood, checked battery cables, all secure.
Back inside, tried again. Same condition.
Turned headlights on to check brightness, seemed dim in the lighted parking garage.
When I turned them off, you could hear an electrical component(s) making a buzzing(?) in front of my left knee under the dash.
Turned ignition back on, instrument panel immediately lit up normally, and started normally.
What the heck happened?? What do I have to do to not have this happen again??
Old Sep 18, 2012 | 10:55 AM
guitarpicr's Avatar
guitarpicr
Check your battery output or take & have them tested - Sounds like they might be weak.Make sure all connections are clean & tight also
Old Sep 18, 2012 | 11:04 AM
th67ss's Avatar
th67ss
X2...........Maybe just a bad battery or batteries?
Old Sep 18, 2012 | 12:07 PM
empiretc's Avatar
empiretc
clean your battery terminals and see what happens. if that doesn't help, have the bats load tested.
Old Sep 18, 2012 | 02:36 PM
lhud's Avatar
lhud
Don't overlook the hot cables and grounds on the batteries as they can corrode within the insulation and appear to be full 100% conductors while they may be corroded to half size or less. I'm sure there are some voltage and continuity checks to verify this. Just don't overlook the possibility.
Old Sep 19, 2012 | 01:24 PM
h2guy's Avatar
h2guy
Nah, batteries checked out good on the tester. Cables look good, no soft spots, very little corrosion.
The clicking/buzzing noise under the dash, coupled with the fact that after turning on headlights, noise stopping, then lights being turned off, then immediately starting normally with all instrument indications normal, means, to me, there was something going on in the fuse/relay box.
If theres identical relays in there, I'm gonna try switching one for another and see if it ever reoccurs.
Old Sep 19, 2012 | 04:12 PM
BillyBob69's Avatar
BillyBob69
Double check the cables. I know what you see may not seem like a lot of corrosion, but I had the same issue with my wife's car. Turned out the corrosion was about 2ft into the cable under the insulation. I just started cutting back the cable until I reached clean copper then attached a new piece of cable with an end on it.
How I figured out it was the cable, I took a length of 10 gauge wire, attached one end to the battery then took the other end and touched it to where ever the original cable attached to and split off to. Finally found it when suddenly everything on the dash lit up as it should, buzzers and bells started sounding normal and the car started normally again. Then started cutting back the original cable and replaced with new.
Old Sep 20, 2012 | 03:29 PM
h2guy's Avatar
h2guy
Well, its been 3 days now since the problem and its never repeated itself. Starting and stopping probably 6=8 times each day.
Starter continues to spin up vigorously each time with instrument panel all reading normal.
Still think its in an electronical gadget under the dash.
The fact that turning the headlights on and off made the "gremlins" go away (so far) in that singular occurrence is baffling.
TexanAmmo
33
Aug 27, 2016 07:20 PM
narles00
2004 - 2008 F150
Sep 1, 2012 11:10 AM
ZekeF3
1997 - 2003 F150
Aug 24, 2012 07:35 PM
Kodiak235
2004 - 2008 F150
Feb 9, 2009 11:09 AM
vicv
Feb 23, 2006 07:50 PM
