battery gauge going crazy
Old Sep 18, 2012 | 02:43 AM
sunbelt57's Avatar
sunbelt57
I was going to work today in my 92 F150 and the voltage gauge started pegging along with the battery idiot light flashing on. I pulled over to look under the hood and check the batteries and found nothing obviously wrong. I started back up again and it was fine. It did the same thing in almost the same spot on the way home but this time the gauge was really bouncing around and the transmission went out of and into gear. I guess the tranny is computer controlled. I have the factory service manuals. I was just wondering where to start. Probably a short somewhere?
Old Sep 18, 2012 | 06:32 AM
Franklin2's Avatar
Franklin2
Take the battery + cable loose, and then take the wires off the alternator and check them for being loose, melted or corroded. Simply taking the connections off and putting them back on may fix it.
Old Sep 18, 2012 | 08:32 PM
sunbelt57's Avatar
sunbelt57
Thanks Dave. As a matter of fact, I just put new post connectors on the other day but it was because I was wiring to an inverter so I'm hoping that's the problem.
Old Sep 18, 2012 | 08:40 PM
Muffinman's Avatar
Muffinman
You got a bad alternator get it checked. Its over heating and the voltage regulator is going out. If you drive it to much it will burn up the wiring or bulbs, if it gets above 19 volts.
Old Sep 18, 2012 | 08:46 PM
sunbelt57's Avatar
sunbelt57
That makes sense. If it was shorting the gauge would go to zero instead of up over 18v.
Old Feb 20, 2025 | 07:31 PM
Jacksonham's Avatar
Jacksonham
1st Gear
I know this post is years old but I have a similar problem. My voltage is slowly rising on my gauge in the cab. Starts out slightly above where it should be and slowly rises. I recently put in a new alternator which should have had the built in regulator. I can only imagine that alternator has somehow gone bad as it it slowly rising and not jumping around. Any thoughts anyone?
Old Feb 21, 2025 | 06:37 AM
Franklin2's Avatar
Franklin2
What year, what model, what engine? Are you looking at the factory gauge?
Old Feb 21, 2025 | 06:42 PM
JimsRebel's Avatar
JimsRebel
You can buy a cigarette lighter voltage meter on Amazon.
It's good to have a second opinion.
97ranger xlt
1983 - 2012 Ranger & B-Series
Mar 19, 2013 04:15 PM
RhondaBruce
Mar 30, 2011 12:33 AM
r0n1n
Electrical Systems/Wiring
Jul 7, 2009 11:40 AM
fairlaniac
Feb 14, 2008 04:04 PM
jhjandal
Aerostar
Dec 5, 2005 08:21 AM
