MASS Air Sensor housing
Does anyone have the exact measurements for the bolt pattern/spacing for this stock MASS Air sensor housing?
I've measured the vertical and horizontal spacing but I could be off by a little and figured these measurements exist somewhere, I just wasn't able to find them.
That mass air meter sucks. Get the newer style 70mm or bigger and then build a bracket.
Sorry. Had to throw that out there cause your sig has supercharger in it.
Why do you need exact measurement. Little bigger drill can make up for some mismeasurement and head of bolt will still cover it up.
I'd still wanna upgrade that maf. Unless its the one with the bigger opening and not just the 55mm opening in the large housing.
