Do all '66 F-100's have the switch and hazzard light mounted in the instrument bezel. It looks Ghetto and looks like Dilbert(WW2 Dilbert not the modern cartoon Dilbert)installed it. I see that it is that way on alot of other pickups so it was Factory or installed at the dealer. My question is are Bezels available without the two holes in the bezel? My 67 F100(RIP) had the switch mounted in the glove box and my '66 A Code Mustang Convertible also has it in the glove box, same switch as my '67 F100 SWB in my 4x4. I Don't want hazzards in my bezel. The switch has the bracket that says emergency flashers that I want to mount under the dash. As for the red light it isn't even needed because you can see when your emergencies are on anyway.
HELP are there ant uncut bezels out there?
Will this Hazzard kit reach to glove box or do i have to mount it under the dash like the aux fuel tank guage switch?
No such thing existed until 1967, as this was the first year FoMoCo offered a 25 gallon auxillary fuel tank. The only tank available for 1961/66's is the in-cab tank.
F100/350: 4 way emergency flasher switch located on the dash, to the right of the steering column, below instrument cluster 1961/66.
Located inside the glovebox 1967/69, located on the dash, to the right of the steering column, below instrument cluster 1970/72.
