Sponsored by: Real Truck
2010 5.4 missfire
Old Sep 16, 2012 | 08:27 AM
S Cesaro's Avatar
S Cesaro
2010 5.4 missfire
I have a 2010 F250 with a 5.4. Truck has 32,000 miles and i am getting a missfire out of 2,3,4. Rough idle and gets worse as truck warms up.
Old Sep 16, 2012 | 11:31 AM
superduty1967's Avatar
superduty1967
2010 5.4 missfire
I had the same issue once and was bad coil #1, changed coil and plug, done. but by all means if you are still under warranty, let the dealer take care of it.
Nelson
Old Sep 16, 2012 | 09:13 PM
redford's Avatar
redford
FTE Leadership Emeritus
Just let the dealer fix it. That is what warranties are for.
Old Sep 17, 2012 | 02:03 PM
SuperDutyScaler's Avatar
SuperDutyScaler
i second that! NO way i would still have a warrenty and try to fix plugs on these gas trucks. Plugs built with three pieces that pull apart and stay in the block, 100 dollar tool to remove it. Let Ford fix it!
Old Sep 18, 2012 | 09:22 AM
S Cesaro's Avatar
S Cesaro
Found problem
The converter is clogged. It now becomes the dealer problem. Converters are covered up to 80k and or 10 years, fed law. Ford has a recall on the issue. Thanks for everyones input.
Pastor Scott
Sep 2, 2017 12:57 PM
ugh3012
May 15, 2015 09:14 PM
janvan
2004 - 2008 F150
Mar 6, 2009 07:34 AM
jgc2521
Modular V8 (4.6L, 5.4L)
Dec 7, 2004 11:00 AM
