Cam for '89 460
Talked to Charles at Camcraft, and he can grind me a 206/210 @.050" w/.490/.505" lift on 112lsa with lifters for $200. I think I have my bro-in-law talked into headers to replace his cracked manifolds too. Should be a real stump puller
Good luck with yours.
I finally changed to mass air with my 460, but the CJ cam from motorsport was installed with speed density and a chip and it work wonderfully for pulling trailers and around town, kept me in the power range while pulling hills 4th gear @ 2500-3700 rpm still building power rather than above it which was my problem with the RV cam also improved mileage while pulling by .5-1 mpg. The Speed density was irritated by the drop in Manifold pressure. Hypertech, Street & performance and several other companies have special chip burning departments. are you uping the compression ratio? I ran a little better than 9.5. definately open up your exaust ports and put in larger valves, your heads on a flow bench will floww a little better than a stock set of CJ heads. the speed density will work with head work like that. you can use a 1970 429 timing chain to place your cam @ top dead center.
My .02
Dusty
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4039&.jpg
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=474&.jpg
Why Buy new when you can build and tailor it cheaper?
F-350 4x4 ext cab Short Bed Green Monster, it is now Sporting a 300HP 715lb/ft Dyno rated 5.9L 12v Cummins diesel w/ NV4500 5spd and custom NP205 ford T-case w/ rear spicer 1410 yoke, Converted to Sterling 10.5 gears w/3.73 gears using the 41 spline pinion and 1410 U-Joints, Power-Lok equipt Dana 60 front, 33's on 16x8" Outlaw II's. (Used to have)205000 miles, Mass air 460 w/ performance heads and a E40d to 5spd conversion and Doug Thorleys. Old EFI 460 @10 MPG to the 12 V @ 23.2 MPG @ 75 MPH and loving it.
My other toy is a '69 CJ-5 354 Hemi 4 spd 4.88's 32x12.50 MThompsons w/ power-lok 44 rear.
